qbart Posted March 26, 2017 Share #1  Posted March 26, 2017 Advertisement (gone after registration) Hi there,   I had a model session with a photography class yesterday.. took around 36 exposures with agfa vista 200 on my leica m2. The film then was sent to a lab and processed within 2 hours. I found out there is like a half black frame on the result and it happens on most of them, and some of the photos looked underexposed. 1 photos in particular looked well exposed, I remember my settings on the day (it was f2 and either 1/250 or 1/125). I should also noted that there are 8 black frames.  My friend pointed out that it could be a shutter problem not closing on properly.  I have attached the result here, anyone had this problem before? Thank you.   Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/270733-help-black-frame-in-leica-m2/?do=findComment&comment=3241792'>More sharing options...
Advertisement Posted March 26, 2017 Posted March 26, 2017 Hi qbart, Take a look here help.. black frame in leica m2. I'm sure you'll find what you were looking for!
TomB_tx Posted March 26, 2017 Share #2 Â Posted March 26, 2017 Yes, sticky shutter curtain where the curtains move at different speeds. A proper camera service will disassemble, clean off the old, sticky lubricants, apply new lubricants, adjust the curtain springs and curtain speeds. A high percentage of the old cameras I've collected show similar shutter issues, but are always fixed by a good CLA. Some will try to fix cheaply by just raising the spring tension, but this causes other problems long term. Link to post Share on other sites More sharing options...
jerzy Posted March 26, 2017 Share #3 Â Posted March 26, 2017 Yes, This is the first curtain which is too slow at the beginning and does not open. Rising tension of the second curtain is not a remedy as Tom wrote, the rest of the frame will not be properly exposed. CLA will cure it. Link to post Share on other sites More sharing options...
qbart Posted March 26, 2017 Author Share #4  Posted March 26, 2017 Thanks everyone for the reply.. CLA is a must then.. another problem is that there are no good repairer here where I lived (Indonesia).. I will try sending it to Leica Singapore. Link to post Share on other sites More sharing options...
