Guest roey Posted March 8, 2017 Share #1  Posted March 8, 2017 Advertisement (gone after registration) In the Firmware 3.0 thread I mentioned that my camera does occasionally freeze. After it locked up a couple of times over the last weekend I spent some time today trying to see whether I can reproduce the problem. As it turns out, I can, however it looks like it is a temporary freeze since if I wait for what feels like 10 seconds the SL does recover and starts working again.  Here are the steps to reproduce the (temporary) freeze:  1. Set drive mode to medium speed 2. Turn off auto review 3. Hold down the shutter to take ~10 shots 4. While the red light is blinking   4.1. Hit the play button (TR)   4.2. Double tap the display (to zoom in)   4.3. Swipe on the display  At that point the display freezes and the camera no longer reacts to any buttons or switches -- including the off-switch. The red light keeps blinking for a while. After another 5 seconds or so the camera starts responding again.  I am sure there are other series of steps that would give the same result. Before I try to narrow this down further (try different cards, different battery, different steps) I would be grateful if some of you could try out the above steps and let me know whether you can reproduce this with your cameras. Link to post Share on other sites More sharing options...
Advertisement Posted March 8, 2017 Posted March 8, 2017 Hi Guest roey, Take a look here How to temporarily freeze my SL. I'm sure you'll find what you were looking for!
mikemgb Posted March 8, 2017 Share #2 Â Posted March 8, 2017 I'm assuming the red light blinking indicates the camera is still writing to the card after a rapid burst of photos, why not just wait until it is done writing? Link to post Share on other sites More sharing options...
leica1215 Posted March 8, 2017 Share #3  Posted March 8, 2017 Don't understand why you want to reproduce the issue? So vey high possibility you will send in your sl for repair soon   Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
AlexP Posted March 9, 2017 Share #4  Posted March 9, 2017 from what you trying to do, it's the buffer issue between your camera and SD card. Even with DSLR like Canon 1dx mkii or NIkon D5, it happen the same. Link to post Share on other sites More sharing options...
Mute-on Posted March 9, 2017 Share #5  Posted March 9, 2017 It's a computer, and you have found a way to force a crash. Now that you know how to do it doesn't mean you should repeat the action. Enjoy it as a camera instead   Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted March 10, 2017 Share #6 Â Posted March 10, 2017 It's probably just unable to process all those commands. However you should send Leica an email outlining your discovery. They may very well look into it. Â Gordon Link to post Share on other sites More sharing options...
AlexP Posted March 10, 2017 Share #7 Â Posted March 10, 2017 Advertisement (gone after registration) It's probably just unable to process all those commands. However you should send Leica an email outlining your discovery. They may very well look into it. Â Gordon i did send Canon and nikon about this same issue 2 years ago and they said it is just the buffer can't keep up writing/display at the same time. They also ask why am i in a rush to view the picture that way? lolz Link to post Share on other sites More sharing options...
Guest roey Posted March 10, 2017 Share #8  Posted March 10, 2017 I have given up on reporting bugs to Leica—never heard anything back from them.  Thanks for all the advice and theories, but I was hoping that I can get some help here to rule out a hardware defect. Hence my request for some brave souls to try out whether they can reproduce the issue. I don't want to send my camera to Leica just to learn that it is a firmware defect.  Any volunteers? Link to post Share on other sites More sharing options...
AlexP Posted March 10, 2017 Share #9  Posted March 10, 2017 try the Lexar 2000X card. See if it will reduce the freezing time. If it is then for sure it is the buffer issue. Or the newest card from sony  https://www.bhphotovideo.com/c/product/1322906-REG/sony_sosd64gbuii_64gb_uhs_ii_sd_card.html Link to post Share on other sites More sharing options...
LD_50 Posted March 10, 2017 Share #10 Â Posted March 10, 2017 I understand "ruling out a hardware defect" but given this is a very specific use case I'm not sure I understand the point. Let Leica know about it and see if you get a response. Â You can probably quickly rule out a hardware issue by trying the same type of thing with slightly different inputs such as higher and lower speed with the same 10 shots or perhaps a few less or a few more, or trying the same with jpeg only or Raw only or jpeg/raw, etc to determine whether you're simply overwhelming the camera's processor and buffering capabilities. Link to post Share on other sites More sharing options...
Jeff S Posted March 10, 2017 Share #11 Â Posted March 10, 2017 Patient...."Doc, it hurts when I do this." Â Doctor.... "So don't do that." Â Jeff Link to post Share on other sites More sharing options...
