Stein K S Posted January 21, 2017 Share #1 Posted January 21, 2017 Advertisement (gone after registration) I guess this is an "old topic" being discussed quite a few times before. But I ask for comments anyway. My M9 bought in 2011 with two batteries has from te beginning given the warning signal about Low Battery when the battery status show appr 50% left... and then closes the camera immediately after a few seconds... I have read comments suggesting that this is part of the "personality" of the M9... but should it really be like this? PS: as described... been like this since both batteries where new... Thanks for all advice... Would Solms be the right way to go...? Quote Link to post Share on other sites More sharing options...
Advertisement Posted January 21, 2017 Posted January 21, 2017 Hi Stein K S, Take a look here M9 battery life. I'm sure you'll find what you were looking for!
TomB_tx Posted January 21, 2017 Share #2 Posted January 21, 2017 I know there was a firmware update that changed the response to battery level, but I think it made the camera shut down sooner, as some had their batteries go flat without warning. I avoided that update as my earlier M9 has always done fine. Quote Link to post Share on other sites More sharing options...
uhoh7 Posted January 21, 2017 Share #3 Posted January 21, 2017 Charge when possible. 50% means...uhoh Individual OEM batteries vary once you've had them a while. Quote Link to post Share on other sites More sharing options...
Stein K S Posted January 21, 2017 Author Share #4 Posted January 21, 2017 Charge when possible. 50% means...uhohIndividual OEM batteries vary once you've had them a while. Yes, and that is what I have got used to (charging at any opportunity... and this is actually never a true problem). But woke up this morning still curious on what after all should/could be expected... ;-) As mentioned; new battery do not change this fact. Regards Quote Link to post Share on other sites More sharing options...
mca Posted January 21, 2017 Share #5 Posted January 21, 2017 I have never had problems with batteries in my M9 and I have never needed more than 2 in a day even if I was shooting all day long, they last forever, nothing like the new mirrorless cameras that run out of battery very quickly. I have 6 batteries in total for my M9 which means I can have 2 sets of 3 on two different bags and whichever I take is ready to go, just choose camera and lenses and off I go (more lenses = bigger bag, less lenses = smaller bag). (also my batteries are all originals, no copies) Quote Link to post Share on other sites More sharing options...
Erik Gunst Lund Posted January 21, 2017 Share #6 Posted January 21, 2017 The original Leica batteries are really good and reliable, I can also go through a whole day of shooting with two batteries, very solid performace! Suddenly after some years of duty they loos the power/performance quickly and then I just replace them. Quote Link to post Share on other sites More sharing options...
tobey bilek Posted January 21, 2017 Share #7 Posted January 21, 2017 Advertisement (gone after registration) Keep topping off charge. Twice a year run down to 20%. None OEM can be problems. Quote Link to post Share on other sites More sharing options...
pico Posted January 21, 2017 Share #8 Posted January 21, 2017 Are you certain that you are using a real Leica M9 battery? There are a lot of clones that do not perform properly. . Quote Link to post Share on other sites More sharing options...
Erik Gunst Lund Posted January 22, 2017 Share #9 Posted January 22, 2017 It's quite easy to spot the non-Leica battery's They are cheap or says 'for Leica' on them. Equally easy to tell when you have the real thing, they come in the usual silver Leica box. If you really want to be double safe buy it at you Leica store or one of the big online stores,,, Quote Link to post Share on other sites More sharing options...
Stein K S Posted January 22, 2017 Author Share #10 Posted January 22, 2017 Hi folks and thanks to all! I feel confident that the batteries are original. And I did the sortware update, however, this "behaviour" was the same before and after. I guess I have got used to this... and in practice I am always ok with two batteries along. i just find it annoying that the camera shuts down more or less without warning and when the green status bar show 50% left... The best to all Quote Link to post Share on other sites More sharing options...
Erik Gunst Lund Posted January 22, 2017 Share #11 Posted January 22, 2017 These batteries are almost 6 years old - worn out, just buy a new set and you will be good to go again. Quote Link to post Share on other sites More sharing options...
Stein K S Posted January 24, 2017 Author Share #12 Posted January 24, 2017 These batteries are almost 6 years old - worn out, just buy a new set and you will be good to go again. Hi Erik I know... now they are. But, as stated the camera & batteries have behaved like this from new (as stated previously)... and I was curious if anyone else have the same experience. It seems like no one do... I`ll buy new ones to ¨verify¨... regards, Stein Quote Link to post Share on other sites More sharing options...
Ko.Fe. Posted January 24, 2017 Share #13 Posted January 24, 2017 Maybe giving it some rest might bring it performance back. I have fifteen years old shaver and battery in it was not as good as new, I left it unused for few months and it it helped. My 2008 DSLR original battery was not holding charge well, I added three non OEM, kept original unused and now it is back to normal. But it depends on battery quality. My M-E OEM Leica clearly labeled as made in China and it doesn't sounds promising. My DSLR and shaver batteries were made in Japan... Quote Link to post Share on other sites More sharing options...
uhoh7 Posted January 27, 2017 Share #14 Posted January 27, 2017 Batteries wear out, you know. OEM only for this camera I tried..... Quote Link to post Share on other sites More sharing options...
Gregm61 Posted January 30, 2017 Share #15 Posted January 30, 2017 I have four OEM batteries for my M9. Three of them vary from 2-5 years old and typically show just short of 100% when fully charged (8+hours in the charger). The 4th battery is one I just purchased brand-new from B&H last month and charges to 100%. The more you use them, the better job they do of holding a charge/lasting more shots. I tend to use my M262 more so if I use the M9 after an extended time, it usually take 2-3 charge cycles for them to "build up", but their life per charge still falls well short of the higher capacity battery used in the M262. Quote Link to post Share on other sites More sharing options...
pgk Posted January 31, 2017 Share #16 Posted January 31, 2017 I still have a couple of batteries from when I bought the M8 and they still seem to work ok in my M9s. At minimum they must be at least 8 years old and may be as old as 10. If I'd bothered to number them properly I would know. Yes the M9 does give a low battery warning, then shuts down, though in practice I can't say that battery capacity has ever been a huge issue and I've rarely needed 3 batteries in a day. So far, after 10s of thousands of shots on 5 digital Ms (I sold the M8s and then the M8-2 to upgrade to M9s) I've only had one battery die and that refused to recharge, oh yes and I dropped one and of course it bounced and shot straight down a drain . Quote Link to post Share on other sites More sharing options...
Stein K S Posted February 1, 2017 Author Share #17 Posted February 1, 2017 Hi and thanks again to all! And to pgk: you confirmed the quick shut down (which actually makes the shut down warning valueless...)... Thanks and I agree... With two batteries I have always been ok after all. I just find it strange that Leica being so absolutely presice on most issues seems so "off" concernings batteries... Stein Quote Link to post Share on other sites More sharing options...
yeahyoung Posted February 19, 2017 Share #18 Posted February 19, 2017 (edited) I've had similar issues with two batteries I got with a used M9, one always displays 100%, the other always displays "turn camera off". I emailed Leica Wetzlar and they asked me for photos of the two batteries then sent me two brand new ones with no questions asked. I have not had a chance to test the new batteries yet as the M9 is also with Leica for a sensor replacement. Edited February 19, 2017 by yeahyoung Quote Link to post Share on other sites More sharing options...
JohnnySeven Posted March 24, 2017 Share #19 Posted March 24, 2017 I burn through a lot of m9 batteries clicking through hundreds of images per day. I have 1 original m8 battery that is still holding its own. 2 out of 3 Leica batteries that came with my m9 have kicked the bucket. I started buying the $20 knock offs and found that they will not display an accurate state of charge, they will make your charger flash like a disco but they work. So i just have as many as i can fit in my pockets while shooting and blast away until they're dead, and do a battery reload on the fly. Depending on the temperature and my chimping frequency I can usualy get about 3-400 snaps out of a battery. So far I have not had a total failure with a knock off. Quote Link to post Share on other sites More sharing options...
Sub'erman Posted March 26, 2017 Share #20 Posted March 26, 2017 This thread has gotten me curious: I have two batteries for my M9. Is there a serial number or anything else that shows me that they are original Leica batteries? Quote Link to post Share on other sites More sharing options...
