Hello, i found a list of how the MP differs from the M6:
Viewfinder
·  All optical parts are now coated;
- The viewfinder window has a new scratch-resistant coating;
- The roof prism has a black coating to reduce stray light;
- Improved illumination of the viewfinder frame and increased 2nd image contrast;
-  Flare reduction by adding an extra lens in the vicinity of the masks;
- To provide better illumination of the viewfinder frame and a reduction in reflection, the shape and the hole contour allowing light in the viewfinder was changed;
- The top cover is milled from one piece in brass, which ensures in the advent of heavy mechanical stress distortion is largely excluded;
- A two-stage battery icon informs about the condition of the batteries;
Electronics
- The exposure meter electronics have been revised and updated;
- A processor now allows a digital regulation for programming in production and servicing. By avoiding the use of potentiometers, the durability and stability are increased;
- Improved linearity of the exposure meter ensures accurate exposures over the entire operating range;
- A voltage regulator ensures the correct supply voltage even with weak batteries;
Flash mode
- It can now also sync flashes with the camera without a battery in the camera;
(The camera does not support TTL flash mode).
- The starting slope of the hot shoe is integrated into the housing;
Film advance:
- The film advance is smoother and softer with optimized gear shapes;
- Through better friction material selection, the friction disc of the film reel enables a quieter film transport and a higher long-term stability;
Scope Of Supply:
· Additional battery cover with coin slot is provided;
Shutter:
- The ground plate of the shutter brake is now made of a bronze alloy, whereby the adjustments remain more stable and durable;
- The saddle spring for the friction brake is now made of a wear-resistant material;
- The saddle spring of the friction brake is also made thinner in order to increase its reaction speed;
- The leaf spring for the brake (yet another leaf spring in the camera) is changed from bronze to more durable steel;
- A more elastic second friction spring has been chosen to provide better possibilities of adjustment and to guarantee long-term stability;
  • 2 weeks later...
Yes - the extra body height really helps the handling when using the larger fast lenses
Yes - for short frantic bursts, it does help zip between shots while keeping framing ( and unlike the M9 and MM does not freeze just a the point of most duress )
Yes - the extra weight stops the camera bouncing around so much when carried on the shoulder or chest.
No - 95% of the time it's just dead weight.
Ultimately:
Yes - it's a super classy retro mechanical contraption;  how could anyone not want one.
Hi all, I was wondering if it worth to add a Leicavit to my future MP Black paint.
Any suggestion?
Thanks
Leicavit certainly has some advantages. I had it for a time, but the most comfortable advantage, having a small body, was undone by the Leicavit. I sold it with a profit so no harm done...
Viewfinder
Electronics
Flash mode
Film advance:
Scope Of Supply:
Shutter:
The MP also bounces better, than the M6. Everyday use sometimes takes it's toll. Last week the MP accidentely slid outof my Billingham, dropping on a wood-concrete floor. Luckily no harm done exept a little shining spot on the chrome cap.
It all adds patina.
You can't call yourself a photographer if you've never dropped a camera!
You can buy a second hand MP or stock new MP and then send the camera to Leica HQ.  They can then change the cover for you, or even better yet: Change it yourself and save time and money.
Trying to understand if it is worth to configure the MP a la carte or standard. Do you think vulcanite is much better than the standard skin? Thanks
The standard skin is great. I would not trade it for a vulcanite although it looks more classical.
nice camera , but you have a strange way of focusing . I use a M6TTL and a 35 lux asph. But I guess if I would start again I would go for the cron 35 asph. , which is more user friendly .
Etienne Michiels
Why is a 'Cron more user friendly than a 'Lux? I have both and they both seem quite friendly to me.
gone with the wind
Here's mine - now after a 0.58
0.58?  Good choice!   :)
