If you're referring to ZoomP's MP, it's an MP Classic. No meter.
Explains the meter groove on the shutter speed dial.
Do I understand then that there are 2 versions of the MP?
With and without meter and the Classic is with no meter?
Never knew that....so an MP Classic is really an M2 :-)
ANDY
Guest cwcheung
ANDY
Hi Andy
No. There is only 1 version of MP in current production. MP Classic is a limited edition set (total 500) with a black paint 50/2 summicron lens.
More information about MP Classic (from A visual library on selective LEICA M-Series rangefinder cameras)
http://www.mir.com.my/rb/photography/companies/Leica/Leica-M3/Leica-MP/index4.htm
Rgds
Edited by cwcheung
ANDY
The MP Classic was a limited run special edition. I'm not sure that counts as a separate "version" seeing as it wasn't in regular production and availability.
0.72 MP with lens carrier, 35 Summicron asph & 90 Elmarit
Less, IMO. It adds mass, and adds depth to the right side of the camera; I find that the knurled knob tends to rest in the palm of my hand. I never grip the mounted lens. The only drawback (apart from the added weight around your neck, which is of course lens-choice dependent) is that vertical shooting is slightly more awkward.
The Lens Carrier-M itself is light, btw. I also add a body cap (I always tend to have one handy becaues I also use b2b coupling rings) and use it to store small things inside, like a lens cloth. Finally, I have amended one body cap with the addition of a tripod mount; this makes a good, centralised anchor-point for a monopod or stringpod.
Simples :D
Regards,
Bill
It's interesting to note that MPs still have the Leicameter groove in the shutter speed dial, even though they have a built in meter. I'd not noticed that before.
Hmm. I've just realized that I have a replacement shutter speed dial on one of my MPs that doesn't have the cutout for the meter. It came from Leica a couple of years ago and the numbers were not filled with paint, so all the paint is black. Must be old stock or something?
You have the usual dial. :)
Pete
All this is way too confusing for me. My MP3 has a cutout in the dial, Andy says the regular MP has it too (post #2117). :confused:
The MP-Classic and MP-3 are both limited Editions and the only MPs that have the cut-out-dial. All other (regular and limited) have the "normal" dial.
Standard MP - no meter nudge in shutter speed dial:
OT: Does this forum now have an automatic limitation for 800px image links?
Originally wanted a used MP but ended up swapping for a new in box MP Classic instead.
My 2nd M body was a black MP but sold it to fund for a M8 a few years back. Been missing it since then.
Here's some pics:
LFI softies from Tim Issac.
This classic MP is by far my favorite MP (if I could afford one). Simple look without any meter reminds me of classic Leica. I wonder wether the frame lines are also simple framelines like M3/MP(first generation)/M2. I also wish it had a self timer.:D
So, writing as an MP and M2 user I don't see the point of paying the MP premium for what is essentially an M2..?
Regards,
Bill
Hi Bill
Less is more, kiss
But you correct on another plane it is simpler buying a M2 unless you need a motor or Leicavit, & the M2 can do IXMOO.
Noel
Regards,
Bill
Bill,
Aside from whether it's worth it or not (subjective) flare-free viewfinder, different frame lines, brass gearing giving smoother recock, black paint option.
Pete.
I think that you will find that an M2 has brass gears too.
I had understood that, amongst other things, the M2 was produced as a less expensive version of the M3 so I presumed it would have steel gears. Have I got that wrong?
Pete.
