Guest cwcheung
My MP Classic
Very nice lenses, to go with it ;-)
I am also already in love with the Leicavit MP - I use it for about a week and it is the perfect addition to the MP.
After using the MP now for a while, I plan, to get MP advance levers for all other Leica film bodies.
The MP lever is superior in the way, that you do not have to pull out the advance lever first, to be able, to wind, but you can directly wind on - this is much quicker and smoother as the tippy plastic levers (although less technically ingenious, but more practical indeed).
But seriously - you should take that protection film off the camera - it is meant, to wear after all ! ;-)
Guest cwcheung
I will. IMHO, Leicavit is the best accessory for film M.
Edited by cwcheung
not to sound slow, but
but what exactly within a leicavit makes it work? (ie: how do the guts work to move the film along and whatnot)
Jason
Think about the Leicavit as a motor drive, that attaches through the one round coupling in the bottom of your Leica, which advances the camera, but without battery power.
It has gears in the housing, that transfer the linear motion of the lever into torque to the coupling (it doesn't flip, but moves linear, always perpendicular to the bottom plate).
Every complete pull of the lever translates to one complete advance by the normal advance lever of the camera.
The Leicavit can advance the frame a lot quicker, than you can with your right thumb.
When using the Leicavit, you also can keep the camera planted to your eye, as you don't have to move it away from your face, to get access to the advance lever (especially helpful for left eye shooters).
The great thing is, that with Leicavit attached, you can use both the normal advance lever and/or the Leicavit, to advance the film, depending on situation.
The advance lever is a bit more silent.
You can advance the film with the advance lever one handed, holding the camera min your right hand only with multiple small strokes.
But you can also use the Leicavit, when it counts.
I find also, that it makes shooting tele lenses more comfortable.
The camera is slightly higher, slightly more hefty and the lever can be a help in stabilizing the camera, when connecting to your left ring finger, while framing at low shutter speeds.
It is a perfect match!
Ahh... so it's like a 'mot' for an R-body, but instead of a battery powering it, you power it by flicking the lever. I'm an SLR guy (I have a Flex SL) so i don't own an MP (I wanted a Leica, but the SL was the only one within reach :o ). I do love the simplicity of them and the quiet operation (the SL is the 35mm equivalent to a cannon). Insofar as use, how does one focus a rangefinder as opposed to an SLR? (Seeing all those MPs is making me want one badly... so I want to learn how they work for that day where I can add myself to the ranks)
Jason
the chain and 2 springs, i take it are the push pull for the stick thing that pokes up? and when i flick the handle, it pulls the chain, one spring shrinks, one expands?
But what hooks to the film sprocket to drag the film? Like a sprocket axle on an SLR? And what are those weaknesses I hear about with it?
(SOrry, this is all interesting to me)
Guest thremur
That's an older Leicavit. I wonder of the design has changed that much since then?
They say that in the new one is a drive belt and no chain anymore...
Most pleased with the MP.85 and 50 Summilux (pre-asph) combination
Edited by Eisemann
Peter, you may find this site interesting. Tom Abrahamsson who designed and made a "rapidwinder" whilst Leica were in the phase of not making them a few years ago.
He also makes one for the M2, which Leica do not, and it allows the use of self load IXMOO cassettes which is a serious "IMHO" shortcoming of the current MP offering.
RapidWinder.com Home
I had a Rapidwinder for a while, having bought it as a set with a Rapidgrip. I still have the grip on my M7, but in spite of being a left-eyed shooter I never really got on with the Rapidwinder. That said, it was a beautiful piece of engineering, made with all Tom's attention to detail. It was indeed belt-driven with a toothed rubber belt a little over a quarter of an inch wide, as I recall. It was quiet and smooth in use, but just didn't suit my method of working any more than a motordrive does. The only other thing I remember was that you had to do a little DIY... Leica would not provide Tom with the little spoked wheel that the film drive "petals" fit into so you had to unscrew that from your own baseplate and fit it to the Rapidwinder. This was one of the things that put me off, because it meant you couldn't switch easily between the two.
Regards,
Bill
I bought a "tulip" from Don Goldberg (DAG camera parts) and added it to the Rapidwinder I once had. The screw is there, and once you have the part it is a 30 sec fix. I sold the Rapidwinder as it wasn't for me, couldn't get comfortable with it. I'm now using a Motor-M and like that a lot.
Carl
The nice thing about the Rapidwinder or Leicavit, compared to the Motor-M is, that it lacks the bulk, weight and the grip, keeping the sleekness of the pure MP body.
It is also quite a bit less noisy.
I also like, that it is fool proof in operation.
My Motor-M has locked already two cameras, from which one has to go to Leica, to be reanimated (M7).
Jason
Hi Jason
If you can forgo the nice black paint a chrome M2, with dealer warranty is about 400GBP, a used CV f/2.5 35mm lens about 200GBP.
You may find you like the M2 better (than a MP), they dont accept leicavits though, but unless you can only use your left eye you dont need a baseplate winder, the lever just flicks effortlessly.
You set the lens to six foot and shoot them between the eyes
Noel
