sharp 35mm M lens
orc999
I went to the shop and tested summicron asph and the summilux fle. the summilux is sharper at f2 and quite usable at 1.4. traded in my v4 + about 1100US for a used one and I'm happy with the results. Vignette is a bit on the strong side at 1.4 but I kind of like that.
There is kind of a punchy look to it, I like the clear rendering and I don's see character missing.
Now as the money is gone I'm not looking back. nice lens, light, 1.4, sharp.
...and it has a focus tab :)
Well done. Vignetting looks too strong if your lens is coded though.
thx. There also is some shadow on left and right, might not be all from Vignetting.
My lens is coded. However I use it on the SL with a Kippon adapter(not reading code). There is the option to set it to 35mm summilux in the menue(which I usualy forget when changing lenses).
When I set the lens in Lightroom, nothing is happening on lens correction, that goes for all of my M lenses. Why is that?
[...] My lens is coded. However I use it on the SL with a Kippon adapter(not reading code). There is the option to set it to 35mm summilux in the menue(which I usualy forget when changing lenses).
I have not enough experience with SL & LR sorry but you have to tell the camera what lens you're using i suspect. I would think of buying a Leica adapter if you don't like chimping but other colleagues here will certainly have better ideas than i do.
