volcaremos Posted September 28, 2016 Share #1 Posted September 28, 2016 Advertisement (gone after registration) Hello fellow Leica Q owners I seem to be unable to use my Leica Q in AF mode. The MF sign is constant in the top right corner of the EVF/LCD and no matter what I choose in the Menu I am unable to activate AF. I am stuck and frustrated. User error or technical glitch? Any ideas welcome cheers William Link to post Share on other sites More sharing options...
Advertisement Posted September 28, 2016 Posted September 28, 2016 Hi volcaremos, Take a look here Leica Q - AF issue. I'm sure you'll find what you were looking for!
Flu Posted September 28, 2016 Share #2 Posted September 28, 2016 (edited) Could it be that your manual focus ring is not in AF position? If so, turn your focus ring until it clicks into the AF position. Edited September 28, 2016 by Flu 1 Link to post Share on other sites More sharing options...
Leica Guy Posted September 29, 2016 Share #3 Posted September 29, 2016 Ditto. More than once I was in manual focus and didn't realize it. Try turning the focus ring then making certain it is in the locked AF position. 1 Link to post Share on other sites More sharing options...
Leica Guy Posted September 29, 2016 Share #4 Posted September 29, 2016 That cannot be changed in a menu. It's a lock on the focus ring. 1 Link to post Share on other sites More sharing options...
Iduna Posted September 29, 2016 Share #5 Posted September 29, 2016 William, welcome to the forum! As already mentioned by Flu ans infiniumguy, there is no glitch or fault in the menue. Most of the time the one to blame is oneself. It happened to me more (!) than once that the AF ring was not properly in its lock. This is a thing you will learn to manage and if you leave the stadium of grappling with the handling you'll fell that this camera is a smooth and versatile tool. 2 Link to post Share on other sites More sharing options...
volcaremos Posted September 29, 2016 Author Share #6 Posted September 29, 2016 Thank you all. I worked this out late last night when I had lost all hope. And felt understandably silly. 1 Link to post Share on other sites More sharing options...
nick h Posted October 19, 2016 Share #7 Posted October 19, 2016 Advertisement (gone after registration) I have had a few recent problems with autofocus. The first thing was that the autofocus looked like it was working, but somehow the image didn't look sharp enough once it had 'focussed', in camera. On checking the playback, the focus was off - every shot. The guy in the shop did a factory reset and it worked again. Not sure what he did. Took a while going through to re-set it all up again. The most recent issue was that I put AFL on the zoom crop button on the back of the camera in my user settings. Except, that it was not focus lock, it was actual focussing using that button and that button only (and not the shutter release button)! My fault, but somewhat different definitions to how Nikon, for example, work. Another trip up to the shop to get the camera back... Link to post Share on other sites More sharing options...
yakima Posted September 13, 2017 Share #8 Posted September 13, 2017 Hi nick h I had the same problem. Got the camera on a Friday and went on holiday on the Saturday so didn't have time to familiarise myself with the Q. The battery was almost out so thought it may be the lack of power causing the focussing error or possibly the camera not autofocussing at close range. Having now returned from holiday and going through the shots in Lightroom some frames are indeed well out of focus. I have my zoom/focus lock set on AFL as I won't use the zoom function. Can you explain what you mean by it not being focus lock but actual focussing as I want to get to the bottom of this so it doesn't happen again. Do you mean autofocus is disabled using the button? Link to post Share on other sites More sharing options...
yakima Posted September 13, 2017 Share #9 Posted September 13, 2017 Addendum to last post. Think I have found the answer. I must at some point have pressed the back button, and having previously assigned it to focus lock meant that it remained in that mode until I turned off the camera or pressed it again to exit the mode. One day was not enough time to aquaint myself with the feature. Link to post Share on other sites More sharing options...
nick h Posted December 20, 2017 Share #10 Posted December 20, 2017 Sorry, Yakima, I hadn't been checking on my posts and just saw this. Basically, with other cameras the AFL lock means that once pressed the focus will be locked, but no other functions will be affected. Not so here, as it stopped the shutter release button from focussing, however it appeared to be focussing (as it whirred and seemed to focus). My eyes are a bit dodgy so cannot see that acutely and a lot of shots were only a bit off, but enough to ruin the shot. Turns out with that option on, the ONLY way of focussing is with that button. Which is fine as long as you know that and shoot accordingly! Link to post Share on other sites More sharing options...
