asimplefarmer Posted September 24, 2016 Share #1 Posted September 24, 2016 Advertisement (gone after registration) I have the rare 35mm f1.5 LTM. I have a cheap Chinese adapter (which I'm assuming is the problem). The lens focuses fine on my 7s but adapted on my m240, I have to focus a bit to the left of the RF patch to get it in focus. My 28 elmarit and 50 planar focus fine on the M. So should I shell out $75 for a camera quest adapter? Link to post Share on other sites More sharing options...
Advertisement Posted September 24, 2016 Posted September 24, 2016 Hi asimplefarmer, Take a look here Adapter or lens problem: Canon 35mm LTM . I'm sure you'll find what you were looking for!
jankap Posted September 24, 2016 Share #2 Posted September 24, 2016 Your lens has an infinity lock? See the knob at 10 o´clock. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! In that case you need an adapter with a cut-out. You should search for a Leica IRZOO adapter. In the picture one can (perhaps) read "28-50". I use the older type with the text "M2 50 --- M3 28-50" for my Canon 28mm. Jan Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! In that case you need an adapter with a cut-out. You should search for a Leica IRZOO adapter. In the picture one can (perhaps) read "28-50". I use the older type with the text "M2 50 --- M3 28-50" for my Canon 28mm. Jan ' data-webShareUrl='https://www.l-camera-forum.com/topic/264861-adapter-or-lens-problem-canon-35mm-ltm/?do=findComment&comment=3117843'>More sharing options...
vanGeist Posted September 24, 2016 Share #3 Posted September 24, 2016 I have the rare 35mm f1.5 LTM. I have a cheap Chinese adapter (which I'm assuming is the problem). The lens focuses fine on my 7s but adapted on my m240, I have to focus a bit to the left of the RF patch to get it in focus. My 28 elmarit and 50 planar focus fine on the M. So should I shell out $75 for a camera quest adapter? First, get either a Leica adapter, a Voigtländer adapter or a Novoflex adapter. Cheap adapters are often the root of the problem when focus errors occur. I highly recommend to get one of the mentioned adapters, that may solve the case. If that does not help, you may think about getting a CLA for you lens. Link to post Share on other sites More sharing options...
TomB_tx Posted September 24, 2016 Share #4 Posted September 24, 2016 While the 7s has basically the same flange to "sensor" distance as a digital M, film behaves differently, both by having some thickness to the light sensitive layer (while a digital sensor is much more a single plane), and by having some flex or bulge to the film plane. So lens focus tolerance on film is not as critical as digital. While most of my film-era lenses (both Leitz and Canon LTM) are "fine" on M digital, when looking really critically they could be tuned to do better at a given aperture. Almost all fast film era lenses (the 35 1.5 qualifies) have some focus shift to the rear as they are stopped down. Many lenses were factory set to have perfect focus one to two stops closed from wide open, so they shift slightly forward wide open and slightly back stopped further down, rather than shifting all one direction from perfect focus. On film this isn't noticed, but digital is more critical. Don Goldberg noted two of my 1950s 50 Summicrons were perfect at f 2.8, just as designed to be. If changed to be perfect wide open they would not be as good stopped down. While it could be your adapter, it also may just be a characteristic of the lens used on digital. You should do a careful focus test of the lens at different apertures and distances to see how it might shift. IF you always use it wide open, it could be adjusted for that, but if you most often use it stopped down some, it should be set for best average focus. Don Goldberg can calibrate most lenses if they need adjusting, and has had fast turn-around lately. Link to post Share on other sites More sharing options...
jaapv Posted September 25, 2016 Share #5 Posted September 25, 2016 Your lens has an infinity lock? See the knob at 10 o´clock. 35elmar35.jpg In that case you need an adapter with a cut-out. You should search for a Leica IRZOO adapter. In the picture one can (perhaps) read "28-50". Unknown.jpeg I use the older type with the text "M2 50 --- M3 28-50" for my Canon 28mm. Jan An old cut-out one will give "no lens attached" problems. The infinity lock on this lens is well clear of the mount, so it can use a modern adapter. Link to post Share on other sites More sharing options...
asimplefarmer Posted September 25, 2016 Author Share #6 Posted September 25, 2016 I appreciate all the answers. I ordered a new adapter from camera quest. hopefully that'll solve my problem, if not, the lens off to get CLA'd its such a sharp lens, even starting at f2 Link to post Share on other sites More sharing options...
