Brass M8
meuser
Hi
I know this properly has been discussed before (can't find a clear answer anywhere), but i want to ask anyway. Is the standard Leica M8 (black) brass underneath? Im not talking about the chrome/silver or the M8.2. Im talking about the regular black M8. If yes, will using fine sandpaper etc. be the way to get the lovely brass showing?
Guest Her Berger
Hello Lenny*! :D  Yes the top plate is always brass.
* in-joke ;) welcome to the forum
Sure?
I had both. The M8 and the M8.2.
My regular M8 had a zinc top plate.
But you're right. Usethre .2 to get the brassing. The M8 is a black beauty.
No, it is brass. However, I can understand that you are confused, as  black chrome  has a silvery nickel layer underneath. A black chrome camera will "silver", not brass. Make a deep scratch and it is nice and yellow. The last series to use Zinc for the topplate was the M6.
Obviously the M8.2 which is powder-coated will show brass immediately through the black.
Guest Her Berger
Ah, thank you.
So if I use fine grain sandpaper the black chrome m8 will brass if I sand it enough?, right?
Here is a post by Ernstk, one of our Members, who used a Dremel to "brass" his M8.
http://www.l-camera-forum.com/topic/259525-replace-m8-shutter-or-lcd-rear-screen/page-2
If you are patient sanding you'll even be able to expose the inside...
:lol:  :lol: , yes, haven't seen a black chrome "brassed" nicely so far.
Faking it "almost never" looks right!  OTOH, the Lenny Kravitz version M-P, looks nice enough...as one would expect designed by him & copied from his own naturally worn cameras.
Jaap likes brassing on other people's cameras... ;).  I got hooked on brassing from my Nikon FE2.
Please post some pics...I do believe it could be done well.  It's all a matter of patience and cutting grades...and thinking of wear points.
Good luck meuser!
I am fairly neutral about brassing - on the right camera for the right reason it can be nice. Faked brassing - yuk...
On my own cameras - if I happen to have a black one I will mostly upgrade to silver after a few years..
