Guide on how to focus EVF on Leica M (at overgaard.dk)
Overgaard
I sometimes have the feeling when I use the EVF with a lens wide open (for example the 90mm APO at f2) that the range that should be in focus referring to the in red highlighted area is a bid bigger/wider that the area that is actually focused when I look at the picture on a big screen.
Anybody else experienced that kind of issue?
Hey Thorsten! Really enjoyed that one.
BTW, do not set the preview to 1 second, set it to "hold rel. button". That way it will revert to the active EVF readout as soon as the camera finishes processing.
Yes, you are not the only one who have said that. I think looking at the image and not the red outline is right. Especially with wide angle lenses, the red outline turns on further behind and inf front of what is actually really in focus.
That is indeed the case, and the reason that Leica has chosen such a subtle setting of the peaking. The more obvious ( I would say intrusive) it gets, the less accurate it is. I once tried to photograph a herd of Zebra with a Sony and the whole EVF turned red.
I find that Leica's peaking works by far the best with long lenses and macro, less so with medium focal ranges, which is quite logical within the concept of the camera. After all, it has the rangefinder for that use.
I agree. Peaking is not a reliable way to focus in LV. It is very approximate. Even with different levels of peaking, sharp lenses will peak too much, and softer lenses will show none. Areas of high contrast like zebra lines will show false results too.
Live View is not a viable solution with the M240 due to having to open the aperture manually to achieve high contrast--it is a labor intensive calisthenic required for critical focus. Furthermore, the lack of an electronic first curtain in the M240 requires the opening and closing of the focal plane shutter twice which causes a delay in taking the picture and unnecessary additional shutter slap. The manual apertures of Leica M series lenses fundamentally excludes Live View as a viable solution for Leica M cameras in the future, which is probably why the Leica engineers have patented an electronic range finder that is not through the lens, not off the sensor, and therefore not affected by the aperture setting.
As I said - conceived for long lenses and macro (and wideangles, but who cares about focus stopped down then :D ) In the case of long lenses, one will be using full aperture, or nearly so, anyway, for macro it is usually tripod work. That virtually eliminates this issue.
Wow - I guess I need to stop using my EVF on the M-P, then. Thanks for showing me the light!
Thanks, very helpful article. What a difference having the EVF in 'b&w' makes. I have always struggled to see the focus peeking lines, but in this mode they light up very well. A revelation! Brilliant!
Hi Thorsten. That pesky pedant again!
The first time Stephan Daniel was talking about EVF's was NOT in 2010 at the LSHA meeting. It was at a much more significant time.:
The meeting of Leica Forum members in Solms in mid-2009 when he dropped the bombshell of the discontinuation of the R series. At that meeting he went into the assessment of the quality of EVFs by Leica and he took a quick survey of the interest in EVFs by the members present. It was a clear indication of Leica's route map for  future  systems other than the M.
