AKorenc Posted July 27, 2016 Share #1 Posted July 27, 2016 Advertisement (gone after registration) Hi, I've just recently purchased a Leica Q to add to my Nikon D-SLR system and just today I also updated the firmware to ver. 2.0.I'm using the camera in aperture priority mode and single-shot mode 95% of the time I'm using it.But only today I noticed something strange; when I use it in continuous [C] shooting mode, the exposures after the first one are different than the first one (and all except the first one being the same). As if the camera does not lock the exposure parameters after it's done with recording the first shot. This is not strange by itself, because the camera should change the exposure in such cases IF NEEDED, but in my case this happens also when the lighting situation does not change one bit. Basically the camera changes exposure parameters in fixed lighting conditions - which does not seem the proper way ... Anyone else noticed the same? Link to post Share on other sites More sharing options...
Advertisement Posted July 27, 2016 Posted July 27, 2016 Hi AKorenc, Take a look here Q; exposure issue in continuous shooting mode . I'm sure you'll find what you were looking for!
rent Posted July 27, 2016 Share #2 Posted July 27, 2016 Have you turned on exposure bracketing by accident? How much does it vary? 1/3 stop could be normal. 1 or 2 stops would certainly be strange. -alex Link to post Share on other sites More sharing options...
AKorenc Posted August 8, 2016 Author Share #3 Posted August 8, 2016 Thanks for the reply.I'd say the difference is 1/3 to 1/2 of a stop. The problem occurs while shooting at all aperture values except wide-open at f/1.7.Why do you consider that "normal"? There's clearly something wrong with the way the camera is stopping down the lens' aperture ... and it does bother me.So, is it really just the way it works, are you all experiencing the same behaviour? Link to post Share on other sites More sharing options...
viramati Posted August 8, 2016 Share #4 Posted August 8, 2016 I can confirm a very slight difference and in Lr6 adding .05 on the exposure slider equals them up so a difference of about 5%. Nothing that would make any real life difference but I don't know why. Link to post Share on other sites More sharing options...
biglouis Posted August 8, 2016 Share #5 Posted August 8, 2016 I've been using exposure bracketing a lot recently - in fact it is implemented very well on the Q, imho - this sounds like it to me. Check the menu setting for Exposure Bracketing and I bet it is set to a value other than 0. Otherwise there is some issue with the camera but I have never noticed a problem with continuous shooting - although now I come to think of it I probably only use it with bracketing. LouisB Link to post Share on other sites More sharing options...
Iduna Posted August 9, 2016 Share #6 Posted August 9, 2016 I think the bracketing mode was on, this can be suspected from your description how it varies. Go to the menue and check this out and Switch it in "0" ! Link to post Share on other sites More sharing options...
stefanusj Posted August 9, 2016 Share #7 Posted August 9, 2016 Advertisement (gone after registration) i also experiencing the same issue. exposure change around 1/3. bracketing mode is 0. Link to post Share on other sites More sharing options...
viramati Posted August 9, 2016 Share #8 Posted August 9, 2016 I am surprised people are saying as much a 1/3rd of a stop. I see it but it is so slight as to make no difference if editing a RAW file and not really an issue Link to post Share on other sites More sharing options...
beez Posted August 10, 2016 Share #9 Posted August 10, 2016 I haven't experienced this - I use continuous a lot in the medium speed. For those of you that have had this problem - have you looked at your camera data on those successive frames to see if the aperture or shutter speed data is different from frame-to-frame in the burst? Link to post Share on other sites More sharing options...
krsboz Posted August 14, 2016 Share #10 Posted August 14, 2016 I have experienced this and thought I had lost my own marbles when it happened. I burst shot a static scene, barely swiveling the camera to the right during the burst - with zero lighting change. And while the first frame was properly exposed, the subsequent ones were almost totally blown out. Exp bracketing was not on. Link to post Share on other sites More sharing options...
Herve5 Posted August 14, 2016 Share #11 Posted August 14, 2016 I'd say the difference is 1/3 to 1/2 of a stop. What do you read in the EXIF data? Link to post Share on other sites More sharing options...
Guest Posted August 14, 2016 Share #12 Posted August 14, 2016 Danke für die Antwort. Ich würde sagen , der Unterschied 1/3 bis 1/2 eines Anschlags ist. Das Problem tritt bei allen Blendenwerten außer aufgerissenen bei f / 1.7 beim Schießen. Warum gehst du der Meinung , dass "normal"? Es ist eindeutig etwas falsch mit der Art und Weise der Kamera Abblenden wird die Linse 'Blende ... und es mich stört. So ist es wirklich so , wie es funktioniert, werden Sie alle das gleiche Verhalten erlebt? EV = adjustment on one point ? Link to post Share on other sites More sharing options...
beez Posted August 15, 2016 Share #13 Posted August 15, 2016 I have experienced this and thought I had lost my own marbles when it happened. I burst shot a static scene, barely swiveling the camera to the right during the burst - with zero lighting change. And while the first frame was properly exposed, the subsequent ones were almost totally blown out. Exp bracketing was not on. Depending on which metering mode is engaged, and where in the frame the metering is taking place, exposure can change - sometimes drastically - if you move or change the camera's field of view. This is especially true if you are in spot metering mode - in this mode, the spot meter is reading precisely in the green auto-focus box. If you move the camera, and the AF is focused on something else, the exposure will change. There can also be changes in the exposure if you;re using center-weighted or pattern (sometimes called matrix) metering modes. Your eye compensates for the change in exposure - and it all looks like the same light, but to the camera, even small changes of where it's pointed can change the exposure. Link to post Share on other sites More sharing options...
krsboz Posted August 19, 2016 Share #14 Posted August 19, 2016 Depending on which metering mode is engaged, and where in the frame the metering is taking place, exposure can change - sometimes drastically - if you move or change the camera's field of view. This is especially true if you are in spot metering mode - in this mode, the spot meter is reading precisely in the green auto-focus box. If you move the camera, and the AF is focused on something else, the exposure will change. There can also be changes in the exposure if you;re using center-weighted or pattern (sometimes called matrix) metering modes. Your eye compensates for the change in exposure - and it all looks like the same light, but to the camera, even small changes of where it's pointed can change the exposure. That's a very simple and valued call that I totally overlooked. I always shoot in spot metering - so I'm sure that was the culprit. Makes complete sense. Thanks for the insight.. Link to post Share on other sites More sharing options...
