chris_livsey Posted February 26, 2017 Share #21 Posted February 26, 2017 Advertisement (gone after registration) I wonder if the 4 screws disappeared when the added the top screw to the bayonet flange? 709420 has the top screw and the 4 screws: http://www.ebay.co.uk/itm/Mint-Leica-M3-Double-Stroke-35mm-Rangefinder-Film-Camera-first-year-1954-Rare-/162258614014?hash=item25c75df6fe:g:91cAAOxy9eVRPuab As does 704006 http://www.ebay.co.uk/itm/1954-Leica-M3-Double-Stroke-w-summicron-50mm-f-2-First-year-704006-x00485-/172389813812?hash=item28233bce34:m:mdYqyvyCcb5i3SRYDnMRcEA 757709 has 4 screws and frame preview. http://www.ebay.co.uk/itm/Leica-M3-Rangefinder-Film-Camera-double-stroke-chrome-/292033603291?hash=item43fe8f26db:g:IyoAAOSwx6pYqsn5 But has this been added later? I thought from 785801 but if it was it shows it could be added with the screws in place. 703157 is the same, preview with screws too early a number. http://www.ebay.co.uk/itm/Leica-M3-Gehause-Body-/161972239640?hash=item25b64c3d18:g:EyoAAOSwezVWuIvG Was each camera actually unique? Link to post Share on other sites More sharing options...
Advertisement Posted February 26, 2017 Posted February 26, 2017 Hi chris_livsey, Take a look here Leica M3 variations - 1 . I'm sure you'll find what you were looking for!
Leicaiste Posted February 26, 2017 Share #22 Posted February 26, 2017 I wonder if the 4 screws disappeared when they added the top screw to the bayonet flange? That is also maybe the reason for the larger spacer ring bellow the advance lever : to help secure the top plate without the four screws. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/262754-leica-m3-variations-1/?do=findComment&comment=3222236'>More sharing options...
Leicaiste Posted February 26, 2017 Share #23 Posted February 26, 2017 One can also see on the picture just above that the older shutter speed dial was a bit taller (with 1/2/5/25/50/100/250 etc) than the later version (1/2/4/8/15/30/60/125/250 etc). Link to post Share on other sites More sharing options...
jerzy Posted February 26, 2017 Share #24 Posted February 26, 2017 on top of chganges and modification which are visible like all mentioned above there were as well other modifications to the meachanism, but as well to the functionality of the camera. And some of them were being kept secrect, Leica did not made a lot of noise when introducing it. Such example is releasing the wind mechanism after the shutter was cocked. M3 has a blockade against film wind when the shutter is running. With early models the wind mechanism was released when the first curtain finished it's travel. This means that with long speeds (like 1 sec) you could wind the film when the second curtain was not fully closed, thus ruin the picture. Later, it has been changed to the second curtain releasing the wind mechanism after it finished the travel. When exactely this modification has been introduced I was not able to find out, anyhow my 7008xx and 702xxx do not have this modification and 707xxx has it already. Very often however early M3 received this modification automaticaly (even without informing the user) when they were in service. Link to post Share on other sites More sharing options...
Leicaiste Posted February 26, 2017 Share #25 Posted February 26, 2017 I wonder if the 4 screws disappeared when the added the top screw to the bayonet flange? Looking at this replacement M3 black paint top plate, it seems that you are right. http://www.leicashop.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/2/5/25181_31.jpg Link to post Share on other sites More sharing options...
willeica Posted February 26, 2017 Share #26 Posted February 26, 2017 My M3 DS from 1955 has the top screw on the lens mount and the four screws on the top plate (front and back). It does not have a frame lever, however. I wonder was it necessary to remove the screw on the top plate front ( right side looking towards it) to allow for a small link of some kind between the lever and the actual frames. As they were removing one screw, Leica may have decided to go all of the way. My 1955 M3 DS also has a smaller ring under the shutter button than a later M3 SS which I have in my collection. Just a few more pieces of evidence to add to the mix. William Link to post Share on other sites More sharing options...
