diddus Posted July 1, 2016 Share #1 Posted July 1, 2016 Advertisement (gone after registration) So, I was in Wetzlar to get my M9 checked out and repaired after an accident... while waiting I couldn't resist checking out the S. When I came home the files amazed me and I couldn't stop thinking about owning one ... sell the 240 + 50 Summilux ASPH and try to get a used S2 .... I was back in Wetzlar on tuesday and left the outlet with a S (006) and 70 Summarit-S. Crazy. Anyhow, as I started playing with tethering (and having trouble setting that up...) I finally though I had managed it... when the camera stopped working. As in, it does blink ... a lot .. but it is neither recognized by the shuttle anymore, nor does it fire on it's own. I have tried hard resets (battery out ..) and managed to get back into the system where I was able to also reset the camera. Still, the top LCD does not turn on and neither do the LED's inside the Viewfinder. I cannot take pictures either. It does allow me, from time to time, to change the Quick menu and even let's me do other stuff in the menu. Mostly it blinks red though and the screen tends to flash every once in a while when pressing buttons. Any suggestions? Link to post Share on other sites More sharing options...
Advertisement Posted July 1, 2016 Posted July 1, 2016 Hi diddus, Take a look here I finally got me an S (006) aaaand broke it right away?! . I'm sure you'll find what you were looking for!
erlingmm Posted July 1, 2016 Share #2 Posted July 1, 2016 So, I was in Wetzlar to get my M9 checked out and repaired after an accident... while waiting I couldn't resist checking out the S. When I came home the files amazed me and I couldn't stop thinking about owning one ... sell the 240 + 50 Summilux ASPH and try to get a used S2 .... I was back in Wetzlar on tuesday and left the outlet with a S (006) and 70 Summarit-S. Crazy. Anyhow, as I started playing with tethering (and having trouble setting that up...) I finally though I had managed it... when the camera stopped working. As in, it does blink ... a lot .. but it is neither recognized by the shuttle anymore, nor does it fire on it's own. I have tried hard resets (battery out ..) and managed to get back into the system where I was able to also reset the camera. Still, the top LCD does not turn on and neither do the LED's inside the Viewfinder. I cannot take pictures either. It does allow me, from time to time, to change the Quick menu and even let's me do other stuff in the menu. Mostly it blinks red though and the screen tends to flash every once in a while when pressing buttons. Any suggestions? Sounds like you need to send it in. But, have you tried to re-install firmware? Have you used the latest, official tethering SW? IN that case I would say this is Leica responsibility. Link to post Share on other sites More sharing options...
diddus Posted July 1, 2016 Author Share #3 Posted July 1, 2016 Sounds like you need to send it in. But, have you tried to re-install firmware? Have you used the latest, official tethering SW? IN that case I would say this is Leica responsibility. Yeah, all the latest firmware used etc. Wouldn't even let me reinstall the latest firmware. Now I was able to connect the AC Adapter and it works again ... It seems that the battery was empty? A little surprising since it showed 3/4 full when I checked earlier. With less then 200 shots fired that probably shouldn't happen. I will try to figure it out over the weekend. Maybe it's the battery. Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted July 1, 2016 Share #4 Posted July 1, 2016 New batteries take a few cycles to get to full capacity and to calibrate the usage meter. Wait till you've run 4 or five recharge cycles before pronouncing the battery faulty. It could be. But it's likely just running itself in. Gordon Link to post Share on other sites More sharing options...
xiaubauu2009 Posted July 11, 2016 Share #5 Posted July 11, 2016 Welcome to the S world... Link to post Share on other sites More sharing options...
mgrayson3 Posted July 11, 2016 Share #6 Posted July 11, 2016 Whoops. Wrong thread! Link to post Share on other sites More sharing options...
albertknappmd Posted July 11, 2016 Share #7 Posted July 11, 2016 Advertisement (gone after registration) That was close but agree that battery needs multiple cycles.. Please attempt to drain it as low as possible before recharging and do this several times. If you encounter repeat issues after cycling a few times, just return the battery for a new one. Also you should always have a spare when shooting anyway. Good luck with your Leica! Albert Link to post Share on other sites More sharing options...
