kivis Posted June 17, 2016 Share #1  Posted June 17, 2016 Advertisement (gone after registration) If I have a Leica M-D (Typ 262) and a non Leica brand lens (Zeiss, etc.), am I giving up any functionality over using a Leica brand lens? Link to post Share on other sites More sharing options...
Advertisement Posted June 17, 2016 Posted June 17, 2016 Hi kivis, Take a look here Newbie question for the Leica M-D (Typ 262). I'm sure you'll find what you were looking for!
a.noctilux Posted June 17, 2016 Share #2 Â Posted June 17, 2016 No, if you don't worry about EXIF data or you can code them as the nearest Leica lens. Â Arnaud Link to post Share on other sites More sharing options...
kivis Posted June 17, 2016 Author Share #3 Â Posted June 17, 2016 Coding - what does that entail? Cost? Link to post Share on other sites More sharing options...
a.noctilux Posted June 17, 2016 Share #4 Â Posted June 17, 2016 Coding non Leica lenses would not be easy and with the M-D, input a lens type is not possible as other M (type 240/262). Â Some people would "code" their favorites lenses Leica or not with black marker, then try if this change in the right way. Then, they may find that with "coded lens" would have vignetting corrected. If they are happy with that they may "hard code" those lenses. Â Myself, I use all kind of lenses Leica or not M, LTM, and so on, I do prefer the original character of those old lenses with no "software corrected". Link to post Share on other sites More sharing options...
jaapv Posted June 17, 2016 Share #5 Â Posted June 17, 2016 Why shouldn't it be easy? Some brands, like Zeiss, provide a groove for the user to apply dollops of black and white paint for the user to code to the most appropriate Leica equivalent. Otherwise it is easy to Dremel the indentations, or have a technician do so for you. The corrections are not as elaborate as some more modern cameras and limit themselves to vignetting and colour drift. They do not address distortion the character of the lenses. Link to post Share on other sites More sharing options...
jmahto Posted June 18, 2016 Share #6 Â Posted June 18, 2016 Why shouldn't it be easy? Some brands, like Zeiss, provide a groove for the user to apply dollops of black and white paint for the user to code to the most appropriate Leica equivalent. Otherwise it is easy to Dremel the indentations, or have a technician do so for you. The corrections are not as elaborate as some more modern cameras and limit themselves to vignetting and colour drift. They do not address distortion the character of the lenses. One can use marker pen to code but verification will be a problem with MD. You will have to take picture, download to computer and then check EXIF whether correct lens code got picked up (as opposed to checking the code readout directly on rear LCD). Link to post Share on other sites More sharing options...
papimuzo Posted June 18, 2016 Share #7 Â Posted June 18, 2016 Advertisement (gone after registration) You can simplify the process by using a Wi-Fi memory card (the bottom plate of the M-D allows it): after taking some shots, you can see the result on a computer, seing the EXIF and the picture effect. Link to post Share on other sites More sharing options...
