Electronic Shutter vs. "normal" Shutter
steppenw0lf
Since the discussions about FW 2.0 I heard that there are two possible shutters: Is it electronic and mechanic or electro-mechanic ?
Can anybody try to explain which shutters the SL offers, the difference between them and finally why the electronic shutter only appears now (and when exactly is it used by the camera).
If the manual tells all this I won't mind a link to it. (And close the thread asap.)
Stephan
I hope others will offer a more technical explanation, but to start it off....
The sensor needs to measure the amount of light collected by each sensel in a given interval. A mechanical shutter (electronically driven) does this by physically closing, emptying the sensels, opening to collect photons, then closing again to allow the photons to be counted.
In my understanding, a purely electronic shutter is not really a shutter, but just a means of measuring the photons falling on the sensels in an interval without physically blocking the light to start with or shutting it off afterwards.
The SL now uses both mechanisms, but the electronic shutter, for reasons I don't understand, is only available at very fast speeds.
I can't answer the other parts of your question.
I think the electronic shutter simply gates the pixels on and then off a very short time later.  Since it takes a significant amount of time to expose and then read all of the pixels out (something like the 1/60 sec refresh rate that LiveView presents.   The 1/18000 of a second while equal in duration at all pixels is not happening at the same time on all pixels. so the exposure might be vulnerable to artifacts that result from the subject moving within the time that it takes for the image all to be collected.  This is just a guess on my part, based on hints picked up in discussions of the electronic shutter issues on other brands of camera.  Has anyone taken a picture at 1/18000 second of a fast moving car, to see if the image slides across from top to bottom, as in early shots with a slow moving focal plane shutter (Lartigue's is best known).
scott
As I have been working a long time in unix support and know the Power chips in depth I would like to make a comparison with the IBM Power8 and the popular Intel Haswell chips. (comparing them to an unknown/anonymous sensor chip in the SL).
The Power8 has a memory bandwidth of           384 GB/s
The Haswell of                                                      68 GB/s
For a transfer of 72 MB (24 MB times 3)   they take around:   (let's assume 100 MB per image to make it simpler)
Power8                            1/3840    s           =         0.00026 s
Haswell                            1/680      s           =         0.00147 s
So they would offer a faster refresh rate (than 1/60 s), but they are using much more energy than a camera can provide.
(Just some sort of "back of the envelope" plausibility check.)
GPUs are also in this range (beginning at 14.4 GB/s up to 336 GB/s), but even bigger in size and energy consumption.
Any hints where these discussions about sensor chips can be found ?  A special forum ?
Thanks.     Stephan
The SL has, like most CMOS sensors that use it, a rolling electronic shutter. When used (only between 1/8000 and 1/16000 in the case of the SL) the camera reads one line of pixels at a time in sequence from the bottom of the sensor to the top (which is seen in reverse because the image is inverted). These then *build* an exposure. It's like an electronic version of a swing shutter like those found in Noblex panoramic cameras. Each line reads for the correct amount of time but the overall shutter time is the time it takes for the camera to read and write each line and turn that into a single file.
You could potentially see rolling shutter effects but these are most visible as the shutter speed (read speed) lowers so in the case of the SL it's unlikely you'll ever "see" a rolling shutter effect unless Leica decide to make it available at lower shutter speeds as well.
Gordon
But if the electronic shutter exposes one line at a time, even if we count only the exposure time, overlapping readout and control delays, 4000 lines at 1/8000 sec per line requires 1/2 sec!  I suppose the lines are exposed in moderate-sized groups.  A live view refresh rate of 60 to 120 frames per sec (as needed for good autofocus response) would require groups of 30 to 60 lines.
These same issues come up with cameras like the latest Olympus M5 and Hasselblad, which shoot multiple images to be combined in a single frame with sub-pixel resolution, moving the chip after each image is taken. It is interesting to see the gaps between still imaging, video, light field and full-blown computational imaging fill in.
scott
In order to detect the rolling shutter effect, I could imagine that it is a good idea to go to a small airfield with older propeller planes.
The effect should be visible with rotating propeller blades. (easier than following a F1 car, and probably also easier to find on the countryside)
Stephan
Thanks. Stephan
Both CCD's and CMOS sensors have much less throughput, but it's not necessarily because of limitations in processing speed. Generally, the faster you read out a sensor the higher the read noise. A compromise needs to be reached, and that is usually around the 1/60s that allows good Live View performance. Some astronomy cameras in order to minimize read nose take up to 30s to read out the contents of the sensor.
As to the original question... A m chain all shutter has the advantage of no rolling shutter since the exposure takes place during the same interval for all sensels. In the cas of an electronic shutter, the exposure takes place at different times for each row, so you can get what are called "rolling shutter" effects where vertical lines appear to slant on moving objects (or on stationary objects if you are panning).
Leica uses a mechanical shutter whenever it can--up to a shutter speed of 1/4000s--and an electronic shutter for faster speeds where the mechanical just can't keep up.
- Jared
Stephan
Tun a bicycle upside-down and spin the rear wheel in top gear.
Maybe a useful link for general understanding:    http://www.cse.wustl.edu/~jain/cse567-11/ftp/imgsens/index.html
Especially chapter two: "Performance Metrics for Image Sensors".
Stephan
Or this (proprietary but nice graphics about reading out data): Mainly about Exmoor sensor
https://pro.sony.com/bbsccms/assets/files/cat/camsec/solutions/E_CMOS_Sensor_WP_110427.pdf
scott
It's more that the read of line 2 begins before the read of line 1 finishes. It's still one line starting at a time. How fast that is, I suppose that would depend on processor speed and circuitry efficiencies. It'd be something like: L1 on> L2 on> L3 on> L4 on> L1 off> L5 on> L2 off> L6 on, etc.
Gordon
I tried the 1/16,000 sec speed with electronic shutter after upgrading to FW 2.0. See the fan in the centre of the picture. It was running at full speed.
The shutter managed to freeze two out of three blades. It seems as if it somewhat shortened the blade in the bottom left hand corner, and lengthened the one in the bottom right hand corner. The fan was rotating clockwise.
ISO 50,000, f/3.2.
Gordon
I agree.  Staggering the readouts rather than clumping them would give smoother results.  The bandwidth required for signalling and coordinating all of this could be minimized by putting the coordinating logic mostly on the imaging chip.  But the tough part of the job remains buffering and reordering the output lines into a 4000x6000 image that the rest of the camera can handle, and exporting this image 60 to 120 times a second.  That's 14.4  to 28.8 GB/sec, or as much as 150 to 300 Gbits per second, with error correction, which is pretty much state of the art for medium power components (not for your average smart phone).
scott
I missed several notes above.  See Jared's in particular, for the tradeoff between read speed and read noise.
I may be misunderstanding you, Scott, but that is what your average smartphone actually does. It only has an electronic shutter, and (checking one typical shot I took recently) took an 8Mp shot at 1/400s. I used my Olympus OMD EM5ii to take 16Mp shots at 1/60s. The puzzle is not how advanced the technology is (though I'm interested in the technology as a geek) but why Leica has only implemented it at a very fast speed.
Because either:
1. They're concerned about rolling shutter that really shows more at lower speeds. Shouldn't that be a user decision?
2. They didn't realise how useful a silent shutter can be for many photographers. Like weddings, movie sets etc. etc.
3. As usual Leica don't quite get it right first time around.
Gordon
Gordon
I am just guessing, but unless the sensor chip is specifically designed for global shutter operations, a "electro-mechanical" shutter provides better quality (no rolling shutter). At very high speeds the end is reached for the electro-mechanical shutter (or a disproportionate effort is necessary to improve it), while the rolling shutter problem effectively disappears.
Unfortunately we still know almost nothing about the sensor chip (producer, design, specs etc.)
Stephan
  • 9 months later...
