240/262 Shadow Recovery versus M9?
gtownby
I shoot a lot of daylight color with my M9 and don't much need high-ISO performance, per se. I typically underexpose 1/3 to avoid highlight blowouts and pull up the shadows in post. So I would  definitely enjoy some improved shadow recovery and dodge/lighten capabilities. My question: Does the improved ISO capacity of the 240/262 translate into improved manipulation of deep shadows  (at, say ISO 400) over the M9?
My M-P's better than my M9-P for pulling up shadows, but it's still not at the level of my Nikon D800E. The M-P can show an annoying tartan pattern in the noise of low light areas if it's pushed too far, while the Nikon has more random looking noise.
Not so much the ISO performance as the better dynamic range will give the M240 the edge.
I would advise against a blanket underexposure. It all depends on the subject. With very high contrast -1/3rd may not be enough, with a low contrast subject an one-EV overexposure may well be best. When in doubt, switch to manual spot-metering.
I don't use spot metering generally. I never overexpose and often underexpose by one stop on contrasty subjects. Shadow recovery is not a probem with the M240 provided i don't need more than +2 or +3 EV recovery. I only use Capture One though. YMMV.
Yes, compared to M9. Although banding is a concern and there is no substitute for proper exposure (true with M9 as well). I upgraded to M240 from M9 and find it better in terms of highlight recovery.
Although I should add that highlight recovery is fun in the beginning but soon I realized that full black areas are an essential parts of the picture and should not be avoided. Translation: I don't do shadow recovery as much now a days.
Edit: I noticed that you said you shoot mostly in daylight. In daylight M9 is as good as M240. Even for shadow recovery.
This method works OK, however you will be wasting dynamic range in many high-contrast situations. Measuring the scene by spot and exposing exactly will gain DR. It is even more important on a Monochrom.
It's not day and night at ISO 200-400, but what the M262 does SEEM to me to do better than the M9 is, the metering is more conservative. Areas that show a modest amount of clipping on the back LCD often open up in Adobe Camera raw as not being clipped at all. I don't even think about tiny clipped amounts anymore when reviewing a file as I know it's not going to be a problem working around later.
I am a bit new to the M262, that has the same lightmeter as the M240. But it is my impression too, that it tends to overexposure in situations, where I would not expect ist. Perhaps it is caused by the slightly different metering field on the shutter curtain comparing to the M9, which I have been used to about six years.
Elmar
