bobbywise Posted March 26, 2016 Share #1 Â Posted March 26, 2016 Advertisement (gone after registration) As already discussed, the 40 mm Summicron-C brings up the 50/75mm frame lines. Filing back the part of the flange which interacts with the frameline selector enables the 35/135 frame lines instead, where the 35 mm framelines are quite close on the M9/MM. Â Anyway, tonight I gradually filed away, incrementally. I haven't quite filed away enough, but interestingly I now get 35/50/75 framelines. This actually seems quite good as the 40 mm kind of sits in between (closer to the 35). Â I'm temped to file a bit more to have a cleaner viewfinder with only 35/135, but having the 50 visible might actually be useful. Â if I don't file anymore, and leave the 35/50/75 framelines, I wonder if the M9/MM will correct the image for a manually selected 35 mm summicron. Any ideas ? Â Happy Easter ! Â Rob Link to post Share on other sites More sharing options...
Advertisement Posted March 26, 2016 Posted March 26, 2016 Hi bobbywise, Take a look here 40 mm Summicron-C interesting filing results. I'm sure you'll find what you were looking for!
AceVentura1986 Posted April 2, 2016 Share #2  Posted April 2, 2016 You can get the same result by slowly moving the frame selection lever to about mid point. Although this would be ideal, my concern is that you'd not be engaging the physical mechanism fully in one setting or the other. Given that this is mechanical, it might damage the mechanism. Maybe.  On on a side note, how do you like the 40?  I've got a 35 and a 50 but feel ones too wide and the other too narrow. Link to post Share on other sites More sharing options...
bobbywise Posted April 2, 2016 Author Share #3 Â Posted April 2, 2016 I ended up filing off a bit more to bring up the 35 mm frame lines. In the end, if felt they are so close to the 40 mm summicron-c at both close and far away. Â I really like the 40 mm as it's in between 35 and 50. I do have the 35 FLE and 50 ASPH, which are larger. I use them quite a bit if I want to use the wide open 1.4 aperture. However, if I want to use a compact kit, I think the 40 mm summicron-c is great and extremely flexible. Â https://www.flickr.com/gp/robertwisbey/g96vE3 Link to post Share on other sites More sharing options...
bobbywise Posted April 3, 2016 Author Share #4 Â Posted April 3, 2016 Link to post Share on other sites More sharing options...
AceVentura1986 Posted April 4, 2016 Share #5  Posted April 4, 2016 How do you find the framelines perform w the 40? I read that at infinity, they're a pretty good match for the M9's 35mm, but up close its a bit looser. Is this true? How do up compensate? Link to post Share on other sites More sharing options...
Rus Posted April 4, 2016 Share #6 Â Posted April 4, 2016 I experience the same 35/50 thing when using an LTM-M adapter. The lens mounts properly and brings up a clean 50/75 frameline, but when I manually push the selector lever back towards the 35/28 position and release it, the mixed frameline appears, every time. A push towards the 50/75 position gets rid of it again. A push towards the 35/28 position produces the mix Link to post Share on other sites More sharing options...
sblutter Posted April 4, 2016 Share #7 Â Posted April 4, 2016 Advertisement (gone after registration) Love that lens, greatest bargain ever Link to post Share on other sites More sharing options...
bobbywise Posted April 6, 2016 Author Share #8  Posted April 6, 2016 For sure it's a great lens (I'm currently using it on vacation over my other lenses due to its portability). Framing close up is ok -- it obviously cuts the image slightly, but once you've learned to compensate (that doesn't take long), the results are bang on Link to post Share on other sites More sharing options...
bobbywise Posted April 6, 2016 Author Share #9 Â Posted April 6, 2016 Some examples of the 40 mm summicron-c framing on the M9P : Â https://flickr.com/photos/8043930@N04/sets/72157664538358744 Link to post Share on other sites More sharing options...
bobbywise Posted April 6, 2016 Author Share #10 Â Posted April 6, 2016 Some examples of the 40 mm summicron-c framing on the M9P : Â https://flickr.com/photos/8043930@N04/sets/72157664538358744 Link to post Share on other sites More sharing options...
Rus Posted April 6, 2016 Share #11 Â Posted April 6, 2016 Very nice photos Link to post Share on other sites More sharing options...
