Collapsible questions
AKW
Dear colleagues,
I´m sorry, if this topic has been dealed earlier, it´s about an older and not so old Elmar-M 2,8/50.
The older lens is around 1969, serial n:o 232xxxx, and the other one 1996, serial n:o 373xxxx.
I used to have one copy 3 decades ago, and if I remember right, the front element, including the diaphragm ring, was rotating as you turned the focusing ring. How is it with these -69 and -96 lenses?
Secondly, is there any differences in image quality? I noticed that the newer one has a 6-blade-diaphragm and the older one has so many blades I could´t count them. That must have some effect to the unfocussed areas and bright spots in it. I presume that the lens coatings has changed as well?
And finally, are both version safe to collapse when mounted to digital-M?
Many thanks,
Arto
The older type is an Elmar.The newer type is designated Elmar-M and is by far the better lens due to a different positioning of the diaphragm and newer coatings. Yes, it rotates on focusing. Yes, it can be collapsed, but should be mounted/unmounted extended.
The Elmar-M has better overall contrast and finer detail resolution than the earlier Elmar, as well as better close-up performance - noticeable at least on film....never used either on digital bodies though.
Thank you for the valuable information!
Arto
Jaap, are you sure???  Many older Elmars _do_front rotate with focusing,  But My Elmar-M _does not_ rotate with focussing.  And I just double checked 30 seconds ago, after having used it all day!
Guy
Guy
Guy
Guy
I'll have to check - you may well be right - I have too many Elmars I guess...:(
  • 2 weeks later...
