For Leica 246 what settings do you leave it on for:
Sharpness:
Contrast:
Toning:
Shading Correction:
moving from original MM so not sure.
thank you
The point of settings is to adapt the camera to your personal preferences. That means there is no cookbook recipe. BTW you are talking about JPG settings here. I would advise you to use DNG and postprocess the images to your liking.
Guest jvansmit
Thank you for fast replies.
Anyone else move from the original MM?
this type 246 feels heavy.
anyone here prefer the original MM over the 246, or does the 246 just take time getting used to?
it took me a while to get used to the slight form-factor difference with the M246, and I even contemplated swapping back to the MM1. I've got used to it now, and prefer it to the MM1
It also took me a while to develop a workflow in LR6 compared to the MM1. I routinely underexpose by at least 2/3 of a stop, and the jpegs are nowhere close to my intended output.
Edited by jvansmit
It is worth pointing out that the settings that the OP mentions can also be relevant for us shooting in raw only since they are applied to the thumbnail image that is displayed on the LCD. Increasing sharpness and contrast will result in a chrisper image to view but be warned that when you increase contrast you will push the the white tones in the jpeg which can lead to the histogram and clipping warnings inorrectly showing burned highlights even though the exposure is fine since they both are calculated from the jpeg data, and the same goes for the blacks of course.
All OFF!!!!!!!!
Even if I used JPEG (which I don't) all the settings that interfere in the photograph would be set to OFF. It then allows me to interfere (by dealing with contrast, toning, sharpness, etc.) with calm reflection when I'm post-processing the image. I don't want to start post-processing with one arm behind my back because the tiny camera brain has screwed up things like contrast and sharpening when Photoshop can do it so much better.
Steve
Edited by 250swb
  • 3 weeks later...
  • 4 weeks later...
  • 5 years later...
