Color filters for m240 b/w vs software conversion.
PaulJohn
I shoot predominantly b&w on my M-P using lightroom to convert with software colour filters to darken skies etc. Any who has done this will know that it has limitations and that the edges of the filtered colored areas become problematic.
Do people still use colour filters in these instances are is there a better software solution?
Also, has the capability of software affected your choice of filters?
With Leica DNGs I find I have to do the minimum of work in LR, assuming I've exposed correctly, I then ship a TIFF to SEP2 and have phenomenol options with the colour filter, and other sliders. Haven't considered lens filters, thought they were for film and digital monochrome users only. Downsides of optical filters for me are cost and inconvenience, plus if you get the choice of filter wrong when you look at the RAW file sometime later, you've limited your options somewhat.
I am trying to get the really dark skies that Ansel Adams achieved with red filters. If there is a tree in the foreground the edges between the tree and the sky go weird as I darken the sky. Applying a red filter in SEP2 seems just as weird as dropping the blues in LR.
Here is an example of photo where Adams employed a deep red filter
https://assets.paddle8.com/510/539/32638/32638-1400264998-25.jpg
I'm not convinced this is achievable in software but would like to be proved wrong.
Actually having tried SEP2 some more it is significantly better than LR. The method is completely different as SEP2 is filtering red where LR is darkening blues:
Darkening skies in LR
Darkening skies in SEP2
The effect on the rest of the image is also different.
That's some shot by Mr Adams!!
Proper notation...  Monolith, The Face of Half Dome, Yosemite National Park, California, 1927
Adams wrote and spoke frequently about this image, as it was the very first one where he 'visualized' the resulting print (or as some erroneously say, 'pre-visualized'....Adams thought this redundant).
Jeff
Well, the good news is that if you don't figure it out right away, you have decades to achieve your desired result....
Adams printed his photograph, Moonrise, Hernandez, New Mexico, 1941  over a 34 year period, with increasingly darker skies as he continually reinterpreted his desired result (maybe he should have called this 'post-visualization')...   http://www.andrewsmithgallery.com/exhibitions/anseladams/arrington/arrington_adams.html
Jeff
Give this a try and see if it helps any.  I'm going to do three posts so the files are big enough you can tell what's really happening.
Start with a RAW color image exposed and processed to your taste. I'm using Photoshop CC, but as the ACR is the same in Lightroom I assume it works there also.
The example happens to represent my idea of correct exposure and processing, but if someone feels otherwise that's fine, the concept is still the same.   :)
Next, open the file in ACR and select the HSL/Grayscale command.  Check the box Convert to Grayscale and you'll get Adobe's idea of what a greyscale converse should look like.  Select the Auto command and it may improve a bit.
Grab the Blue and Aquas sliders and move them to the left to suit.  That gets you to the general neighborhood ow what you might think a red filter would look like.
It's easy to get the sky to turn a solid black, which is not where you are trying to go.  Experiment some.
This is a 200% fro the above image.  The edge between the castle and the black sky is reasonably well defined and displays a minimum of the white outline sometimes seen with Silver Efex or suchlike plugins..  This is from an M8 incidentally.
You will likely need to add a slight S-Curve as demonstrated in the final version below to get the blacks and whites where you want them and may need to fiddle with the midtones as well.  I can't seem to get the very small file sizes imposed of the forum to show the effect very well, so you'll need to experiment yourself.  Hopefully this will get you closer to what you are seeking.
As a practical matter, I find that sometimes this method works best for me and sometimes I just can't beat SEP :)
As I don't use Lightroom I'm not familiar with what commands are available, but in Photoshop you also have the Channel Mixer and the Black and White commands, which do pretty much the same thing with the added benefit of supporting a red filter preset.
I have no idea if this helps get to where you wanted to be or not, perhaps it will provide some ideas.
Thanks for the help. I've previously avoided PS which is a shame as it is more powerful than LR and I am paying for it on CC. My efforts didn't work at first as my sky was too light. I dropped the blue luminance in LR before converting to b/w in PS and that has given me the best control yet. I can actually achieve a complete black sky without compromising the non-sky areas. Not that black is the best image but it shows what is possible.
original image
L1001291 1
step 1
L1001291 1 2
step 2
L1001291 2 1
