MRJohn Posted December 29, 2015 Share #1  Posted December 29, 2015 Advertisement (gone after registration) I have acquired an Apo Cron in June of 2015 (SN4290XXX) and got some quite good shots out of it. In terms of characteristics it is nicely complementary to my 3 other 50 mm lenses, but hence I do not use it all the time.  Interestingly, I noticed quite some flare when I pointed it to WTC1 which had an reflection of the sun on the facade:  There was no flare when the sun-spot was basically in the frame (see example 1 taken with the Apo 50).  Once the sun-spot moved to a corner, or even just outside of the visible frame, it flared big time (see example 2 taken with the Apo 50).  For comparison I used a 28mm 2.0 Asph (see example 3) under similar conditions as example 2. And while it does flare a bit, it is much less than with the Apo 50.  From what I have read any lens can flare but it also seems that the Apo 50 had a particular problem with it in the past. So do you think this is a flawed unit (and I should ship it back) or ist the flare shown here normal and to be expected? Any advice/opinion much appreciated.  Thanks, Mark  PS: sorry for the picture quality, I had to reduce file size for this post  Example 1: Apo 50 no flare Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  Example 2: Apo 50 with flare  Example 3: comparison to example 2; 28 Asph with little flare Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  Example 2: Apo 50 with flare  Example 3: comparison to example 2; 28 Asph with little flare ' data-webShareUrl='https://www.l-camera-forum.com/topic/254942-apo-50-flare-example-normal-or-flawed-unit/?do=findComment&comment=2958062'>More sharing options...
Advertisement Posted December 29, 2015 Posted December 29, 2015 Hi MRJohn, Take a look here APO 50 flare example, normal or flawed unit?. I'm sure you'll find what you were looking for!
lct Posted December 29, 2015 Share #2 Â Posted December 29, 2015 All lenses do flare more or less when a strong light source lies outside the frame, as in your pic 2 if i read you correctly. But the same lenses can be flare free when the same sources are inside the frame as in your pics 1 & 3. Such a flare has nothing to do with the "CVF" (central veiling flare) the 50/2 apo was suffering from at its launch. Link to post Share on other sites More sharing options...
MRJohn Posted December 29, 2015 Author Share #3 Â Posted December 29, 2015 Thanks, lct, I do not see CVF in any of my images with this lens, just the type which I showed. Link to post Share on other sites More sharing options...
lct Posted December 29, 2015 Share #4  Posted December 29, 2015 Don't worry even the Summilux 50/1.4 asph can flare badly when a strong light source (here an halogen lamp) is just outside the frame.  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/254942-apo-50-flare-example-normal-or-flawed-unit/?do=findComment&comment=2958268'>More sharing options...
