Help w Blurred Image
wparsonsgisnet
I would like some suggestions for improving this image (image 1).
Using my MBP, I used Focus Magic (width 2, 100pct), Silver FX Pro (neutral, contrast +5, Shadow 100, and Highlife 100), and Neat Image noise reduction (image 2).
Suggestions gladly welcomed.
I tried shake reduction but the image isn't a great candidate for it. What I would so, if I was desperate to use this image...would be to manually blur his shirt and then add a touch of sharpness to his lips, nose, eyes, cheeks, hair. Just with the regular sharpen brush in Photoshop. I have managed to "rescue" a few images this way. It isn't great but much better than nothing in many cases. Working on the raw file is much better since there is much more information to begin with.
How about the images either side of said image? have you been having other focussing issues recently?
Yeah, I checked motion correction, as well, with no perceptible improvement.
Pix in the group are ok, just some not sharp.
I am working with a 55mm 'lux asph lens, after using a 35 fle for a long time.  I will have to be more patient with this lens.
Thanks for the suggestions.
Gonna try this.  Tnx.
As pico says. The right shoulder is in focus, or nearly so. I would not recommend de-noising the image as de-noising tends to blur the image even more.
Yup, better without noise reduction.  Thanks for the suggestion.
I got a lot of pix I like from this set; it's just this one that the outlaws like and that is o-o-f.
+1. Your lens needs some calibration i suspect. Simple way to make sure is focussing with the EVF and compare.
This is no calibration problem. A lens this far off would be unusable.Focus error, plain and simple, happens to the best of us. No way to salvage the shot. :(
Good shot. After several years the picture will still be greatly appreciated.
That is true - i meant technically. A print of a slightly oversharpened file (with the shoulder blurred to match the face)  could be not too bad, with a bit of luck.
Give it an antique treatment (think Julia Margaret Cameron!) - sepia, possibly with a white vignette.
(I have lots of experience of photographer error :wacko: ).
Yes, I think that might work. The only thing I would be careful about is to blur the in focus shoulder so it doesn't attract attention. It is more pleasing to have everything out of focus than to have the wrong thing in focus.
Also, if you print it small it will appear sharper.
