Need advice on Macbook air
m9photo
I'm sorry if this kind off topic but I need your input, as I will be traveling for 2 weeks and in need of light laptop. I have a 15 MacBook pro but it's kind of heavy so I need something lighter to carry around.
Most likely will use light room for processing, so do you think i5 should be better? Or i7? Also memory 4gb or 8gb? Thanks in advance!
Hello,
Most likely will use light room for processing, so do you think i5 or i7 should be better? Also memory 4gb or 8gb? Thanks in advance!
If you are only buying it for a two-week trip, why not get a second hand one? I have a 2011 11", 1.6 GHz Intel, 4 GB RAM, and it handles LR with ease, the screen is more than adequate for editing on fly, and I use a light external hard drive.
I second the opinion on buying a used one for the trip. On the other hand if you do want to have a second laptop for portability and travel, I would rather go with the 12" Macbook which is smaller than the air and has a much better screen (retina) than the Air line (non retina). As for memory, 8GB and 256GB would be my choice if you want to deal with raws and big files in general.
FWIW I would certainly go for 8GB RAM, and if funds allowed probably go for the i7 - more for the "generation" than the raw clock speed.
Yes, I've decided to get the i7 model with 1.7ghz/8gbRAM/512gbHD. I think I got a good deal for $600.
If you use Photoshop then it is best to have three SD or hard drives and use the two other than the system drive for its scratch files. Plenty of RAM is good but I have never seen Photoshop hit the drives when I had 16gb of RAM.
See, Photoshop has its own swapping and ignores the OS scheme.
