How to let Leica M recognize the R lens?
sunhmt
The Leica M and the Leica R series are quite different cameras, each with its own set of lenses.
The Leica M only recognizes lenses that are built for M type cameras.
You need an adapter in order to mount and use a lens made for the R series on an M. There are adapters made by Leica and adapters made by third parties.
When mounting the  adapter made by Leica on the M, the M will display a list of R lenses and you can pick your lens from that list.
When mounting an adapter made by a third party, there will be no such list and you won't be able to tell your M what lens you are mounting, I believe.
The lens will work anyway, the only difference being that you won't see in the EXIF data what lens you used for a photograph taken with that lens.
