mark_pw Posted November 1, 2015 Share #1  Posted November 1, 2015 Advertisement (gone after registration) The Leica Elmarit-R 35mm f2.8 could have a very short focusing distance, I recently found it could give some quite nice shots on flowers.    I put some other shots at BigBigLens.com - Leica.  Link to post Share on other sites More sharing options...
Advertisement Posted November 1, 2015 Posted November 1, 2015 Hi mark_pw, Take a look here Leica Elmarit-R 35mm f2.8. I'm sure you'll find what you were looking for!
jip Posted November 1, 2015 Share #2 Â Posted November 1, 2015 Used it like this quite a bit on the R8 Link to post Share on other sites More sharing options...
mark_pw Posted November 4, 2015 Author Share #3  Posted November 4, 2015 The close ups are quite impressive even without a extension tube. Link to post Share on other sites More sharing options...
gbealnz Posted November 8, 2015 Share #4 Â Posted November 8, 2015 Bit of a guess, (and yes, OK, I could look it up), but if it's the same filter thread as my R 50mm Summicron (V1), then the Elpro series close-up attachments screw straight on. Try one, they are a great and cost effective addition. Gary Link to post Share on other sites More sharing options...
tobey bilek Posted November 22, 2015 Share #5 Â Posted November 22, 2015 Do not adapt see 6 0r 7 series to 55 mm because you through off the spacing and you make it into something that does not work. Link to post Share on other sites More sharing options...
mark_pw Posted November 25, 2015 Author Share #6 Â Posted November 25, 2015 Do not adapt see 6 0r 7 series to 55 mm because you through off the spacing and you make it into something that does not work. Agree. Use a proper 55mm one on the lens. Link to post Share on other sites More sharing options...
Shac Posted November 26, 2015 Share #7 Â Posted November 26, 2015 Advertisement (gone after registration) Well I have to respecfully disagree - I have one of the Series Elpros with a step ring and it works perfectly fine Link to post Share on other sites More sharing options...
gbealnz Posted November 26, 2015 Share #8 Â Posted November 26, 2015 Hmmmm, I'll sit on the fence, Toby is likely correct, but I too use my two Elpros with adapter rings, self made M44 to M 52 for the T 18-56, and M44 to M43 for the X-Vario. Work? You betcha. Gary Link to post Share on other sites More sharing options...
