Lens selection - manual or auto?
ShivaYash
Hello,
Does this really make a difference? I took two identical images today, one with the 'correct' lens, the camera selected on auto and then again on manual mode, with the actual correct lens.
There was a slight difference but which one is 'correct'?
I think you should spend some time reading your manual to understand how your camera works.
Auto selection can only work with a coded lens, that's the point of having the codes. If you don't have a coded lens then you have to use manual selection of course.
It's not a surprise that you will see some difference between a photo with and without the proper code being applied for most lenses.
Thanks for your helpful reply. Having spent £4k on a body I didn't think of that ;-)
