Guest ralf. Posted July 15, 2015 Share #1 Posted July 15, 2015 Advertisement (gone after registration) I can't believe, but it is true. Anybody else? Link to post Share on other sites More sharing options...
Advertisement Posted July 15, 2015 Posted July 15, 2015 Hi Guest ralf., Take a look here Dust inside of my Q - anybody else with this problem? . I'm sure you'll find what you were looking for!
earleygallery Posted July 15, 2015 Share #2 Posted July 15, 2015 Well, I'm not surprised, and this is why I won't buy another fixed lens digital camera as every one I've had suffered from dust on the sensor eventually. The exception would be a weather sealed camera - dust gets inside through any tiny gaps, and it finds its way onto the sensor. The sensor will be mounted on a plastic panel which will be screwed to the back of the lens assembly. It would be easy to make the join dust proof but they don't. An o ring type seal should do it, and so cheap. Bad luck, you will need to return the camera to be cleaned, but it will no doubt return at some point. Link to post Share on other sites More sharing options...
Guest ralf. Posted July 15, 2015 Share #3 Posted July 15, 2015 So obviously I was naive. I changed from M to a compact camera among other things because I was pissed of by the dust inside the M. I never had dust inside my (sold...) Sony RX1R. Link to post Share on other sites More sharing options...
Doc Henry Posted July 16, 2015 Share #4 Posted July 16, 2015 Qnip, all digital cameras of any brand are dust and for lens fixed on cameras also.James is right (personal experience)To be returned to Leica. Best Henry Link to post Share on other sites More sharing options...
bernie.lcf Posted July 16, 2015 Share #5 Posted July 16, 2015 So obviously I was naive. I changed from M to a compact camera among other things because I was pissed of by the dust inside the M. I never had dust inside my (sold...) Sony RX1R. The compact cameras do have advantages with regards to dust on sensor, but they cannot avoid this problem entirely. Even a sealed camera only seals the body from the outside, but there is nothing keeping particles from the inside to rest on the sensor (most prominent example: the Nikon D600 that kept "spitting" on the sensor). I personally did not have any issues with X1, X2, X-Vario and now the Q. I did have issues with Fuji X100, X100s and the infamous X10. However, there are evidently cases of dust with the compact Leicas. Compared to the M cameras, the dust issue is by far less frequent. The only problem is that you can clean an M yourself, but not the Q. To be returned to Leica. Yes, they'll clean it. If you make an appointment to send it in just in time, you can avoid having the camera with Leica for weeks. Link to post Share on other sites More sharing options...
Guest ralf. Posted July 16, 2015 Share #6 Posted July 16, 2015 I will call Leica and send it back soon. Thank you. Link to post Share on other sites More sharing options...
CYBORA Posted July 16, 2015 Share #7 Posted July 16, 2015 Advertisement (gone after registration) Sorry to hear this problem , I hope this will be fixed in a short time, we will miss your great portrait works. Link to post Share on other sites More sharing options...
viramati Posted July 16, 2015 Share #8 Posted July 16, 2015 That is indeed a large piece of fibre/lint type dust in your first shot. Not expert on these things but becaues of it's siize I would have thought that it has been inside the camera since it was constructed and has unfortuantely migrated it's way onto the sensor as it would indeed be worrying if such a large object could work it's way in from the outside in such a short period of time Link to post Share on other sites More sharing options...
kkonkkrete Posted July 16, 2015 Share #9 Posted July 16, 2015 This is ridiculous. No dust inside my fixed lens camera (Sigma DP2 Merrill) after 3 years and a gazillion shots in all kinds of sandy and dusty conditions. Link to post Share on other sites More sharing options...
Guest ralf. Posted July 16, 2015 Share #10 Posted July 16, 2015 That is indeed a large piece of fibre/lint type dust in your first shot. Not expert on these things but becaues of it's siize I would have thought that it has been inside the camera since it was constructed and has unfortuantely migrated it's way onto the sensor as it would indeed be worrying if such a large object could work it's way in from the outside in such a short period of time The fat button on the left is not small, too. Link to post Share on other sites More sharing options...
viramati Posted July 16, 2015 Share #11 Posted July 16, 2015 The fat button on the left is not small, too. Indeed. I would insist on a replacement Link to post Share on other sites More sharing options...
earleygallery Posted July 16, 2015 Share #12 Posted July 16, 2015 The compact cameras do have advantages with regards to dust on sensor, but they cannot avoid this problem entirely. Even a sealed camera only seals the body from the outside, but there is nothing keeping particles from the inside to rest on the sensor With a compact like the Q, the lens and sensor are effectively one assembly - the lens unit is fixed (usually screwed) to the sensor unit - I opened up my PanaLeica to try to get to the sensor and dust had got in through the small gap between lens/sensor. As I said above it would be a very simple job to make this join dust proof, even if the camera itself weren't dust/weather sealed. It was quite amazing just how much dust had accumulated inside the camera, which was used 'normally'. Link to post Share on other sites More sharing options...
Doc Henry Posted July 16, 2015 Share #13 Posted July 16, 2015 This is ridiculous. No dust inside my fixed lens camera (Sigma DP2 Merrill) after 3 years and a gazillion shots in all kinds of sandy and dusty conditions. Hi KK, http://www.chassimages.com/forum/index.php?topic=123674.0 in a french forum , a topic (translation) "dust on sensor" of DP Merill When turning the ring focus (also valid on autofocus lens), there is a "pull" factor of air , like a mini bellows moving Best Henry Link to post Share on other sites More sharing options...
kkonkkrete Posted July 16, 2015 Share #14 Posted July 16, 2015 Ah, OK, thanks Doc Henry. I didn't say it's not possible, it's just never been an issue in practice for me... even having shot on dusty wind-swept planes. I practically never manual focus with the Merrill though ... but I would with the Q! I would be annoyed to spend that much on a camera and find dust on the sensor that I can't just remove myself. Link to post Share on other sites More sharing options...
Guest ralf. Posted July 16, 2015 Share #15 Posted July 16, 2015 I know that this can happen - but the hope is, it will not. If I am the only one, okay, than it was bad luck. Link to post Share on other sites More sharing options...
kkonkkrete Posted July 16, 2015 Share #16 Posted July 16, 2015 Good luck getting it sorted out! Love the shots you posted BTW. Link to post Share on other sites More sharing options...
Doc Henry Posted July 16, 2015 Share #17 Posted July 16, 2015 Ah, OK, thanks Doc Henry. I didn't say it's not possible, it's just never been an issue in practice for me... even having shot on dusty wind-swept planes. I practically never manual focus with the Merrill though ... but I would with the Q! I would be annoyed to spend that much on a camera and find dust on the sensor that I can't just remove myself. KK , if you like to dissaembly the DP1 by yourself , read the post of "Johan" below, in a same topic (I translate) http://www.chassimages.com/forum/index.php?topic=123674.0 "Hi , broke the camera DP1 (the sensor died after a fall), I disassembled to keep only the lens ..... bah it not easy especially as you can not remove the lens from the front , lens must be removed to get to the sensor..... must remove all the cards and connectors to get there.... So takes courage and a lot of patience" Best Henry Link to post Share on other sites More sharing options...
Mike Rawcs Posted July 16, 2015 Share #18 Posted July 16, 2015 For me, one of the main attractions of a fixed-lens digital camera is not having to deal with dust on the sensor, so this post is disappointing, as I hate dust on a photograph! Hopefully the problem can be fixed as I was probably going to buy the camera but now I'm back to waiting to see what Leica will do next i.e. the rumoured next M. Mike. Link to post Share on other sites More sharing options...
johnloumiles Posted July 16, 2015 Share #19 Posted July 16, 2015 I know this doesn't help now but I tape over the speaker and mic holes with tiny pieces of gaffers tape. The problem is unavoidable but the Q will probably protect against dust better then the X cameras because it has no protruding lens barrel that moves in and out when the camera is powered on. In my opinion that's the number one offender when it comes to dust in fixed lens cameras. Link to post Share on other sites More sharing options...
robert blu Posted July 16, 2015 Share #20 Posted July 16, 2015 i had the dust problem on my X1which had to go to Solms, probably the extending lens is a weak point. But the Q lens is not extending...it can happens... robert Link to post Share on other sites More sharing options...
