Help!!! EXIF misshap :(
julianf73
So this was bound to happen sooner or later, and now I don't know how to fix it: I had the wrong lens profile set, now i downloaded 200+ dng's into Lightroom, and noticed that they are all marked as 50mm Summicron, when they were actually taken with the 21mm Super-Elmar.
Does anyone have any suggestions on how to fix this exif data? I am looking at the documentation for exiftool, and I'm left scratching my head.
Thanks a bunch in advance!!
Happens to me all the time.  I have one lens that is not 6-bit coded and invariably forget to manually select it.  I use Lens Tagger to correct the EXIF
http://www.essl.de/wp/software/lenstagger-lightroom-plugin/
Once the EXIF in the images is corrected Lightroom must re-load the image metadata to show the change.  That will also reset any edits to the image so do that first.
Thanks Luke, I tried Lens Tagger and it seems like it did the job!
However, it also looks like it now saved xmp files next to my dng's. I would like to keep it like I had it before, when Lightroom wrote all the info within the dng. Do you know if there's a way to have Lens Tagger correct directly into the DNG?
Thanks again
  • 2 weeks later...
Just got back from vacation so late in responding.  I don't get an XMP file when I use Lens Tagger, but I don't have the latest version.  I note that the latest version has the option to write the EXIF data to an XMP sidecar file.  Perhaps that option is checked in your installation.
