LCD protector for M240?
Can someone recommend a screen protector for the M240? I just want something simple that fits and will prevent scratches and that can be easily removed without leaving a mess behind. I don't care about clarity at all, and I'm not a fan of Giotto's. Any sugestions w/ links?
Thanks!
I use cut down iPhone screen protectors, they do the job, plenty in a pack, nothing to go wrong. Of course you don't get any bragging rights, they really are very, very cheap, so you get no kudos for paying a 'Leica tax'.
Steve
Yes- but be careful with those that use some kind of adhesive. I know  of a case where the coating on the LCD was severely damaged by the sticky stuff. It is wisest imo to stick to reputed brands and/or use protectors that only use a foam edge or static electricity to stay on.
There are loads of cheap screen protectors on ebay.
There is a difference between cheap and inexpensive.  Cheap is to be avoided.   I have had good experience with Giottos including easy removal.  Saved me at least once on my M9 when the camera swung into something (user error) and the Giottos shattered but the screen itself was undamaged.   To the OP: why do you exclude Giottos from consideration?
+1 on the Sopi glass screen.  I have one on each of mine.  I never liked the Giottos idea because they have an adhesive strip only around the perimeter, therefore allowing a gap under the rest of the glass and a tiny bit of flexure.  That is why they are prone to shatter.  The Sopi have some kind of silicone gel film that adheres the entire glass surface by suction, not chemical bond.  Previously I used Best Skins or Zagg (same thing), they don't peel but are rather thick and not very clear.
I have a Giottos on my M9 and I have no idea how to safely remove it without applying some force. That's why I don't want another one.
They say heat it with a hair dryer, but I've heard that also softens the adhesive Leica uses to hold the LCD cover in place and sometimes they come out together.
What I would do would be to put duct tape across the protector, then slowly pry gently around the periphery with a plastic spatula.  Worst-case if the glass cracks, the tape would hold it together.
Some gentle hair dryer blowing and then you can lift of a corner with a fingernail and the rest comes off easily.  The reason I liked Giottos is that they are absolutely crystal clear.   I say "liked" because I now have an M-P and the sapphire screen does not need it.
I had the sapphire screen on my upgraded M8 and the screen itself didn't get scratched, but the A/R coating did, bigtime.
Generally screen protectors obstruct your view of the LCD far more than a scratch is like to.
Also note that Corning gorilla glass used on the M240 which is one of the hardest glasses out there.
