Leica 1 (B)
Well, it is a (very) long time I did not use a Leica I, but I remember having made various satisfactory tests with either the Adox B&W (KB 21?) and the Ektachrome films. Nevertheless, the latter's colors were very pale and uncertain, understandably due to the non-coated lens.
Hope to have been of some help. Let us know about your results, please.
Pierre
In case you don't already have experience with screw-mount Leicas, loading the film takes extra care. The best way is to start by trimming the start of the film to the recommended shape as shown here: http://jay.fedka.com/index_files/Page345.htm
Apart from that, the biggest issue is, as Pecole said, the low contrast and flare from the uncoated lens. A good lens hood is essential unless the sun is behind you (the codename for the original is FISON).
I used to use an ultraviolet filter or (for monochrome film) a pale yellow filter all the time outdoors. For more realistic-looking skies in monochrome, switch to a standard yellow (Yellow 1).
I guess that nowadays it would be a good idea to choose the more contrasty colour films, and to use traditional monochrome emulsions rather than those such as Ilford XP2 that use the C-41 process. If you search the Film and Darkroom forums here you'll find more information.
Learn how to trim the film leader so you load the camera correctly.
Remember to extend the lens and remove the lens cap before taking a photo!
Don't point the camera for too long towards bright sun - you may end up burning a hole in the shutter.
Wind the film on before trying to set the shutter speed.
That's about all the Leica-specfic advice I can think of.
