M240 with SF58
theoldman
Bottom line is yes, it works with a Nikon SC-17. I have used it that way.
It also works with the multifunction grip and the SCA extension for it, but that is a very much more expensive solution. If you don't need to use your EVF, the Nikon cord is the way to go (Nikon cords other the SC-17 may also work). If you do need the EVF then you are stuck with the grip and extension -- and the extension will have the flash too low IMHO. I had to construct a riser to hold the extension hotshoe higher.
Here is how I get mine out of the camera hot shoe for better balance. I bounce the flash so the lower position is not an issue regarding shadows.
Looks good. I'll borrow your set up technique.
It definitely loses no advantages by being used off camera? Everything works perfectly, even TTL-HSS?
Many thanks for all responses.
I can't speak to HSS as it is not a feature of my M9. But with the correct sync cord (I prefer a shortened Nikon SC-28) all functionality of the flash being in the camera hot shoe is preserved off camera. The only issue I've experienced is due to the SF-58 contacts being located slightly differently than those of a Nikon flash. The result is the connection between the SC-28 and the SF-58 foot is a bit fragile and any movement of the foot in the cord's hot shoe can break the connection. Unfortunately Leica does not offer a sync cord other than the SCA one for the Multifunctional Grip.
I use a Nikon SC-17 and have never experienced an issue with intermittent connection of the contacts. Could this be due to fact you have shortened your SC-28 and the intermittent contact is in the cord?
Rick
Unfortunately no. I've tried a half dozen Nikon cords, both SC-17 and SC-28, with the same result. I know others do not experience this, so I am at a loss to explain it. Perhaps my SF-58 flash foot is out of spec.
@Luke,
What bracket are you using in this setup?
I use a rail attached to an Arca-Swiss plate as shown here.
  • 6 months later...
