gmpphotography Posted October 1, 2014 Share #1 Â Posted October 1, 2014 Advertisement (gone after registration) The sensor in my M8 is in definite need of cleaning. Any recommendations for a cleaning kit that I can use myself? Link to post Share on other sites More sharing options...
Advertisement Posted October 1, 2014 Posted October 1, 2014 Hi gmpphotography, Take a look here Cleaning M8 Sensor. I'm sure you'll find what you were looking for!
lct Posted October 1, 2014 Share #2 Â Posted October 1, 2014 Eclipse works fine. Link to post Share on other sites More sharing options...
doolittle Posted October 2, 2014 Share #3 Â Posted October 2, 2014 Giotto rocket blower followed by Eyelead Sensor Gel Stick. Link to post Share on other sites More sharing options...
Loren Posted October 2, 2014 Share #4 Â Posted October 2, 2014 Giotto rocket blower followed by Eyelead Sensor Gel Stick. Â I agree. The first line of defense should always be the Rocket Blower. That should work in the majority of cases. Â Then I use an Arctic Butterfly brush to get anything that sticks due to static charge that the blower does not. Â Finally, a wet clean may be in order, but once the wet clean is correctly done, a Rocket Blower is about all you should need. Â I think I use the Visible Dust system with Eclipse fluid on my cameras, but there are other systems that work equally well. Â Lastly, I tend to change my lenses with the camera pointing down to minimize dust intrusion. I try to stage my lens changes to minimize the time the camera is without a lens attached. Link to post Share on other sites More sharing options...
mike_j Posted October 3, 2014 Share #5 Â Posted October 3, 2014 I have a Delkin kit with Eclipse liquid, swabs, a mini vacuum cleaner and a magnifier/inspection unit but only because it was a Chrissy present. Â In practice a good blower sorts a lot of the problems and swabs and eclipse liquid does the rest. Link to post Share on other sites More sharing options...
Guest Posted October 6, 2014 Share #6  Posted October 6, 2014 Giotto rocket blower followed by Eyelead Sensor Gel Stick.  After using the "Rocket Blower", which blows only air into the camera body, I screw on my vacuum cleaner first the "Micro Vacuum Attachment Kit", which soft brush has exactly the correct width for the camera sensor.  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  8 Piece Micro Vacuum Attachment Kit Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  8 Piece Micro Vacuum Attachment Kit ' data-webShareUrl='https://www.l-camera-forum.com/topic/234868-cleaning-m8-sensor/?do=findComment&comment=2684344'>More sharing options...
