Battery issue
tredlie
Dear All
recently, I have observed that a newly charged battery was reported as being low on
power by the M9 (bleeding edge firmware). After reinserting the battery everything
seemed fine.
I have two batteries (plus a noname which seems not to work: can't get it charged
so that it is accepted by the camera) and I would thus be surprised, if they are
already at the end of their life cycle.
Any idea what this may be indicative of?
cheers
Tred
I have had two batteries (gen, I long since gave up on the ebay cheapies with my M8) and have used them alternating on my M9-P for the last 2+ years. 16k actuations later they are still pretty good. Every now and then one seems to hold less than 100% charge, I then adjust the M9 menu and leave a picture on the back until it properly dies with zero left in it, charge overnight and all good again.
I know these batteries are not supposed to have memories but completely emptying and then recharging does kick some life back in
Knowing what I do about LCD Screens that is not such a hot idea.
It is not a memory effect you are resetting the calibration between the camera and the battery.
For the screen ratter than the battery ?
jdlaing may be referring to the idea of image burn in that has been an issue since the CRT days. There is an article at http://en.m.wikipedia.org/wiki/Screen_burn-in that discusses this. However for most LCD screens this is only transient. It would be interesting to check with CS though to see if the screen could be damaged by leaving the same image on display for a long time, although I doubt it.
