cbretteville Posted May 3, 2007 Share #1 Â Posted May 3, 2007 Advertisement (gone after registration) Any idea whats the best solvent to use? Need to clean off some ink from coding tests that didn't work. - Carl Link to post Share on other sites More sharing options...
Advertisement Posted May 3, 2007 Posted May 3, 2007 Hi cbretteville, Take a look here What removes Sharpie-ink?. I'm sure you'll find what you were looking for!
chetccox Posted May 3, 2007 Share #2 Â Posted May 3, 2007 I use the wipes that come in the plastic bottle and pull out through the top. They can be purchased at office max etc. They have a small amount of alcohol on them and work great to remove the mistakes. I am sure any paper with a small amount of alcohol would do the same thing. Link to post Share on other sites More sharing options...
blakley Posted May 3, 2007 Share #3 Â Posted May 3, 2007 Nail polish remover is extremely effective. Wouldn't advise getting it on a lens surface, though. Link to post Share on other sites More sharing options...
marknorton Posted May 3, 2007 Share #4 Â Posted May 3, 2007 I definitely wouldn't use nail polish remover. Try something like iso-propyl alcohol or Eclipse fluid which is basically methanol. You could also try neat Vodka... Link to post Share on other sites More sharing options...
mboerma Posted May 3, 2007 Share #5 Â Posted May 3, 2007 Whiteboard marker is really the best solution. Precise and effective! Just use the whiteboard marker to go over the sharpies "permanent" ink and use a clean cloth to remove. Link to post Share on other sites More sharing options...
wparsonsgisnet Posted May 3, 2007 Share #6 Â Posted May 3, 2007 I definitely wouldn't use nail polish remover. Try something like iso-propyl alcohol or Eclipse fluid which is basically methanol. You could also try neat Vodka... Â Â If one plans to do this sort of task over a longer period of time, it will be critical NOT to confuse the liquids being consumed. Â Actually, pretty soon we'll all have a plentiful supply of nail polishes and remover on hand. I'm gonna work on the explanation for my cousins from the dairy farm. Â And, don't forget to take it all out of the kit before boarding a plane. Link to post Share on other sites More sharing options...
cbretteville Posted May 3, 2007 Author Share #7 Â Posted May 3, 2007 Advertisement (gone after registration) Whiteboard marker is really the best solution. Precise and effective! Just use the whiteboard marker to go over the sharpies "permanent" ink and use a clean cloth to remove. Â Off cause! the trick when the permanent marker has been used on the white board. I should have remembered that. Â Thanks guys! Â - C Link to post Share on other sites More sharing options...
grdglass Posted May 3, 2007 Share #8 Â Posted May 3, 2007 I've been using iso-propyl alcohol. Â Helene Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted May 3, 2007 Share #9 Â Posted May 3, 2007 Goof Off. Not joking that is the name Link to post Share on other sites More sharing options...
pfogle Posted May 3, 2007 Share #10 Â Posted May 3, 2007 I use lighter fuel (is that crude?) - effective... Link to post Share on other sites More sharing options...
ken_tanaka Posted May 3, 2007 Share #11  Posted May 3, 2007 Any idea whats the best solvent to use? Need to clean off some ink from coding tests that didn't work.- Carl  http://www.sharpie.com/enUS/FAQ/default.html Link to post Share on other sites More sharing options...
charlesphoto99 Posted May 3, 2007 Share #12 Â Posted May 3, 2007 I use the PEC print cleaner I have laying around. Probably any sort of "Goof Off" type cleaner would work. Lots of them out there made specifically to remove pen marks. Link to post Share on other sites More sharing options...
tashley Posted May 4, 2007 Share #13 Â Posted May 4, 2007 Vodka, chilled (just in case) and applied first with a wet earbud and then scrubbed off with some dry ones. Â t Link to post Share on other sites More sharing options...
