Two rangefinder bag options
Guest NEIL-D-WILLIAMS
  • Replies 44
  • Created
  • Last Reply
Billingham f4.5
Two lenses would fit where the third body is.
Unlike the Hadley Small, the Hadley Pro has a useful grab handle at top and weather protected pocket on the back. It offers more room to maneuver, without being dramatically bigger (although some might disagree) and can also hold an 11" Macbook Air for travel.
Either may do the job (lens sizes of course vary, as well as accessories)….I decided after taking my gear to a Leica shop to compare various options.
Jeff
If it's for using quickly with enough space to easily get bodies with various lenses attached in and out without any fuss (as opposed to compact travelling type storage) I'd say a Hadley Pro would come close. I've got both a Pro and a Hadley Small and while the small could fit everything in, getting it in and out on the go would be very laborious. Better still is the Think Tank Retrospective 7 which is about the same size as the Hadley Pro all closed up, but can expand and give you more room when the flap is open. And the flap is kept shut with hefty Velcro, which can be silenced for walks around a museum, but makes enough noise to wake the dead should any prying fingers try to get into your bag.
Steve
Depending on the lenses, you can get 4 lenses with one on a body, and the second body in the front pouch, with the Leica M Billingham bag. I carry mine with the M6, M-E, 21 SEM, 28 Cron, 50 Lux and 90 Elmarit. The front pouch is large enough for the M6 and film, viewfinders batteries etc.
I will pop over to the camera bag store when I get home and try them out.................I do like the look of the Bellingham, just a pity it doesn’t come in a burgundy/Red
I love Billinghams, I've got 5, but the thing I dislike about the Hadleys, A2 (I have one), and the Leica M bag (had one) is the lack of a zippered closure for the main compartment. Yes, being without a zipper makes for a more convenient shooting bag, but also a far less secure travel bag, and I do a lot of travel. So that might be a consideration, Idk.
I cast my vote for the Billingham Hadley Pro or the Billingham 335; i own and use both and have no complaints about either.
The Pro seems too small for two M camera bodies and four lenses, IMHO. The 335 would be a better fit for that load of gear, but it is more bulky. The Pro would easily fit one M camera with a lens attached and two extra lenses, with the second body and fourth lens being carried about the neck on a strap.
Or perhaps this - http://www.bhphotovideo.com/c/product/1033524-REG/billingham_505334_54_hadley_large_pro_shoulder.html
[quote name=Carlos Danger;2735965. The Pro would easily fit one M camera with a lens attached and two extra lenses' date=' with the second body and fourth lens being carried about the neck on a strap.
[/quote]
Thats what I am thinking............I haver a back pack for traveling I just need a bag for when I am out on the street shooting
I only use the Hadley Pro for traveling, and two cameras with 4 small lenses and accessories fit fine, especially given no need to unpack between destinations. I don't use a bag for shooting unless extreme weather demands, and that would be a much smaller bag.
I think shooting practices account for as much difference in bag preference as bag design.
Jeff
Jeff
I am looking for a bage to carry the items below;
Leica MM
Leica M
50mm Noctilux
50mm APO
21mm Lux
90mm APO
Plus some ND filters and a few color filters, spare battery and viewfinder.
Most of the time I will have one camera and lens around my neck with the rest of the stuff near by for quick changes
Looking at the Pro it looks like it will do the job just fine but I will check it out before I buy
Neil, with the gear you are wanting to put in it, nothing less than a Fogg will do. They are wonderful bags (I have two). But I also have two Billinghams, the Hadley Pro and a 335 and love them as well. As you live in Malaysia, the Foggs aren't too far away. Chiif sells them in Singapore. He has a good website and will ship them off shore. He's sent both of my bags Downunder and the postage was more than reasonable...... As an aside I enjoy your contributions to this forum.
Any particular Fogg model?
+1 on Fogg. Have used for over ten years. Daily bag is B Minor; when travel with Leicaflex lenses use B Major. Can configure the bag as you wish to adjust to your kit.
Strongly suggest get the two way lens holders which allow you to bayonet two lenses together in one spot. Have used old Leica ones and now third party ones which do better with newer lenses that recede further back.
Give Fogg a try as they really work well although bit pricey. Bags weigh almost nothing but great protectors.
I have 3 bags based on size requirements for different M travel/ short transport needs. My Fogg Lyre (smallest) and Fogg b-laika (bigger) have been around for many years (the latter for over 25), now supplemented with the Hadley Pro for largest travel needs. All black, and well worn, costing a lot but never a problem. Each fills a role, with no need to consider others, although nowadays there are plenty of options, and countless posts on the subject…maybe more than any other.
Do a search….and read for days, until you reach redundant overload.
Jeff
