B&W Processing: M240 vs MM
  • Replies 90
  • Created
  • Last Reply
The bit about the post processing is simply incorrect. M240 files in B&w are definitely more complicated.
green trees on a brown cliff are almost on the same range of gray , you cannot get brighter green... post-processing is just impossible in many cases with the MM, the gray scale is very nice but very limited, the M240 is far ahead
green trees on a brown cliff have exactly the same gray , you cannot get brighter green...
If you have never come across the technique you won't know, but for 150 years photographers have used a green (or yellow) filter to 'brighten' green in B&W photography. The MM is slightly green biased anyway, but using a green filter will indeed brighten green in the traditional way. Understanding that a filter is needed is called 'visualisation' (often called pre-visualisation) and is a method of pre-planning the basic tonal balance of the image.
Steve
If you have never come across the technique you won't know, but for 150 years photographers have used a green filter to 'brighten' green in B&W photography. The MM is slightly green biased anyway, but using a green filter will indeed brighten green in the traditional way.
A green filter ? no thanks ! I am not a 150 years old photographer and there is already a green-filter-like in the M240 ... no needs to add one
And of course YOU understand
As I said I shall maybe buy a MM240 , but never that one
And basic photographic technique....
that YOU only know of course
Do you know basic post-processing with Lighroom or capture one ? ... the new basic way to work with a modern camera
If anyone around Oslo has a Monochrom and wants to spend two hours talking about photography and taking meaningless brickwall shots, I would love to shoot some test images side by side with my M240 and come to my own conclusion on the matter. :)
About the discussion on filters, I have to (reluctantly) side with Erick.
With landscapes it's fairly easy to carry a set and use the appropriate filter, but for almost everything else, this don't work.
Would you shoot a wedding and change filters constantly to match the colors of the dresses or neck ties your subjects are wearing?
Would you shoot street photography and change filters according to the colors of the buildings in the background?
The truth is with the MM in those situations you simply stack a light orange or yellow filter and go on, hopping for the best.
In other words, you give up some of your creative control.
And then you go on internet forums and talk about "basic photographic technique". ;)
When post-processing a M240 file you don't use only a green or orange filter , you can use all the colors
+10000
It is well known on this forum that I am an absolute kludge with postprocessing...:rolleyes:
Actually I dislike LR for the lack of control PSCC offers and use C1 Pro as raw developer because it handles 240 colours better, but that is totally beside the point.
You don't need to, because the the image is made by the photographer visualizing and taking it. The computer is a tool, not a replacement of the creative process.
I am starting to wonder which part of the double statement<snip> I am not a 150-year old photographer <snip> deserves the emphasis since you put so much value on the gear replacing ability.
Actually I dislike LR for the lack of control PSCC offers and use C1 r as raw developer because it handles 240 colours better, but that is totally beside the point.
Actually LR 5.5 or Capture One are working fine , it's only a medium format legend that capture one is bette ... and I have both
Wonderful ! I am happy for you
The camera is a tool , the computer is a tool ... and ?
Puzzled - how do you do layers in LR?
Try developing an 240 file in ACR and C1 (and export the PSD 16 to Photoshop CC). It saves lots of work and time.
The ability of the photographer determines the outcome - if he knows his stuff.
I don't use ACR in photoshop but I use Lightroom or C1 and export in Photoshop if needed
both are working very well
I had the MM, M240 and my old MP for 6 months. Used them extensively side by side (the MP less).
I finally sold the MM.
I decided that the M240 was perfect for colour, while the MP would take care of B&W.
The sole interest of the MM was the high ISO range, as pointed out by others, but the superior dynamic range of the M240 resulted in more pleasing images, for me.
For what it's worth.
