barjohn Posted June 26, 2014 Share #1 Posted June 26, 2014 Advertisement (gone after registration) I know that the LCD screen is Gorilla glass so one shouldn't need a screen protector to prevent scratches or damage. On my iPhone and iPad, I don't use any screen protectors and I have never had a problem. However, out of prudence, I always put a screen protector and a UVA filter on my cameras as soon as I get them and a screen protector is available. I had not seen much written on this topic for the T and assumed that it was probably because it hasn't been available to enough users yet. I decided to check the web to see what if anything was available and to give it a shot. I found three screen protectors all stating that they were for the Leica T. One from Lexerd, one from D-Flector Shield and one from ScreenPatronus. I have used Screen Patronus in the past and they have generally been good screen protectors. I had no experience with the other two. Two of the protectors go on dry after carefully cleaning the screen with a micro-fiber cloth and using a sticky tape to make sure any dust, lint or residual finger oils were removed. To my surprise, the Lexerd and Screen Patronus were both the same size and that was about 3/16" short of covering the LCD. Additionally, the corners were curved as if to match the LCD corners but on the LCD the two left corners are curved and the two right ones are 90 degree angles. To put either on the camera the protector had to go to the bottom edge of the camera and not the bottom edge of the LCD or they were too tall and would partially obstruct the hot shoe. One, the screen Patronus had a mat finish and the Lexerd had a gloss clear appearance. Both are relatively easy to put on and the Lexerd came with a squgee card, two finger latex covers and a micro fiber cloth. The ScreenPatronus did not come with anything extra. The last one, the D-Flector Shield was the only one that was cut to perfectly fit the LCD; however, it is the one that requires the greatest amount of effort to install as it uses a wet install method. My prior experience with this type of material has not been good in that it frequently leaves an orange peel effect and bubbles can be very difficult to remove. It does come with everything needed to do the installation and a very thorough set of instructions and links to a video too. I haven't tried installing it yet but may give it a shot this weekend. It certainly looks to be the highest quality of the three. My motivation, in addition to it being my SOP, is that I notice that my finger oils leave a residue that seems to cling to the screen exceptionally well and no amount of rubbing with a micro fiber cloth can remove. My best method of removal has been to use scotch packing tape but I would rather just protect with a protector and not have that hassle. I welcome anyone else's experience and suggestions. I did not see a shot glass protector which I really prefer. I hope this information helps some of you. 2 Link to post Share on other sites More sharing options...
Advertisement Posted June 26, 2014 Posted June 26, 2014 Hi barjohn, Take a look here Screen Protectors - Yes, No, Maybe? . I'm sure you'll find what you were looking for!
jaapv Posted June 26, 2014 Share #2 Posted June 26, 2014 (edited) Gorilla glass can and does scratch. I have a number of iPhones and an M240 to prove it....And I would warn against the Sellotape type of screen protectors, I have seen LCD coatings severely damaged by them. Edited June 26, 2014 by jaapv 1 Link to post Share on other sites More sharing options...
vikasmg Posted June 26, 2014 Share #3 Posted June 26, 2014 My T came with a screen protector. Am I missing something by nor removing it and using the screen naked or with an alternative protector? I do feel that the protector that came with the camera doe interfere slightly with good visibility. Link to post Share on other sites More sharing options...
stuny Posted June 26, 2014 Share #4 Posted June 26, 2014 I suspect that the "screen protector" that came with your T is just the clear plastic that normally comes on so many products, and is meant to be removed. Who out there had a flexible piece of clear plastic over the LCD screen when they unpacked their T? 1 Link to post Share on other sites More sharing options...
vikasmg Posted June 26, 2014 Share #5 Posted June 26, 2014 I suspect that the "screen protector" that came with your T is just the clear plastic that normally comes on so many products, and is meant to be removed. Yes, I'm sure it is. I've just avoided peeling it off till I can find a screen protector. But it's already beginning to show signs of wear so I doubt its meant to be used as a longer term protector. - Vikas Link to post Share on other sites More sharing options...
barjohn Posted June 26, 2014 Author Share #6 Posted June 26, 2014 Gorilla glass can and does scratch. I have a number of iPhones and an M240 to prove it....And I would warn against the Sellotape type of screen protectors, I have seen LCD coatings severely damaged by them. I have never seen the term "Sellotape" what is it? Is it something only sold in the UK? Link to post Share on other sites More sharing options...
vikasmg Posted June 26, 2014 Share #7 Posted June 26, 2014 (edited) Advertisement (gone after registration) I have never seen the term "Sellotape" what is it? Is it something only sold in the UK? Regulars scotch tape - sold everywhere. Some people in the English speaking world (as agains American speaking) still call it that. Though less and less since these days America colonises the world more effectively. The Chinese wait impatiently in the wings but their social capital lags far behind their $ capital. Edited June 26, 2014 by vikasmg Added explanation. 1 Link to post Share on other sites More sharing options...
barjohn Posted June 26, 2014 Author Share #8 Posted June 26, 2014 I'm sure permanently putting it on would do damage with the adhesive eventually bonding to the glass at the microscopic level. Quickly using a piece or better yet painter's blue tape to remove oils and dust should not damage the screen as contact is too brief. Link to post Share on other sites More sharing options...
barjohn Posted June 28, 2014 Author Share #9 Posted June 28, 2014 I put on the D-Flector Shield last night. It turned out that it was 2mm too long and about 1.5mm too short on width. I notified the company and they are sending me a replacement to exact measurement. It went on easier than I expected and is very smooth and clear. The protector with the matt finish just did not work well for the camera as the images lacked a clear sharpness on the LCD and appeared dim in bright daylight. Link to post Share on other sites More sharing options...
colonel Posted June 28, 2014 Share #10 Posted June 28, 2014 I put on the D-Flector Shield last night. It turned out that it was 2mm too long and about 1.5mm too short on width. I notified the company and they are sending me a replacement to exact measurement. It went on easier than I expected and is very smooth and clear. The protector with the matt finish just did not work well for the camera as the images lacked a clear sharpness on the LCD and appeared dim in bright daylight. no matt protectors are any good. they always have a grid which slightly obscures the picture I tend to use screenguard or atFolix rgds Link to post Share on other sites More sharing options...
stevesurf Posted June 29, 2014 Share #11 Posted June 29, 2014 It will be interesting to see if Giottos makes a touchscreen compatible screen protector. What I would do in the meantime is get the crystal film screen protector made for iPhone 5 or Galaxy and trim it to fit. I have found that this screen protector is the most durable, cleanable and repositionable one I have ever used. I've had them on my phones for years and they offer wonderful protection. Link to post Share on other sites More sharing options...
thighslapper Posted June 29, 2014 Share #12 Posted June 29, 2014 I got something designed for an iPad mini (it came as pack of 3) and cut them up to fit ..... perfect on the 2nd attempt. The 'sticky' side is barely adhesive so no worries about removal. Looks and works fine ..... but if anything attracts and shows fingermarks more than the bare screen ....... I have some other larger ones from another source I may chop down and try ...... but I suspect these all come out of the same factory in China and are just cut and re-badged by the sellers ...... Link to post Share on other sites More sharing options...
Slerts Posted February 2, 2020 Share #13 Posted February 2, 2020 My brand new TL2 showed evidence of worn coating on screen after just 6 months of normal use, despite regular cleaning with spectacles cleaner (supplies by optometric shops) and microfibres cloth. The local Leica service told me it was “wear n tear” and suggested applying a screen protector. I would suggest this is mandatory and should have been supplied in the box from factory. Link to post Share on other sites More sharing options...
jaapv Posted February 2, 2020 Share #14 Posted February 2, 2020 On 6/28/2014 at 11:58 PM, colonel said: no matt protectors are any good. they always have a grid which slightly obscures the picture I tend to use screenguard or atFolix rgds I have a matte one which is excellent - I must look up the brand to post. 1 Link to post Share on other sites More sharing options...
Jeff S Posted February 2, 2020 Share #15 Posted February 2, 2020 55 minutes ago, jaapv said: I have a matte one which is excellent - I must look up the brand to post. His post is 5.5 years old. Guess he’s gone through a lot of protectors since then. I’ve never used a protector on camera or phone screen, and have never had problems despite normal everyday use. Must be doing something wrong. Jeff 2 Link to post Share on other sites More sharing options...
AeroMirage Posted February 2, 2020 Share #16 Posted February 2, 2020 I had a TL2 and used this one from Leica. https://us.leica-camera.com/Photography/Leica-CL-TL2/Accessories/Screen-protection-Film-TL Fit perfectly. Link to post Share on other sites More sharing options...
Jake Posted February 6, 2020 Share #17 Posted February 6, 2020 I bought a couple from this place. So far so good. https://www.protectionfilms24.com/c/ALL/leica-cl/ Cheap, and a quality product. Link to post Share on other sites More sharing options...
ramarren Posted February 7, 2020 Share #18 Posted February 7, 2020 "Yes, No, Maybe?" Never used one, never got a scratch or chipped an LCD cover either. I don't see the point, for me at least. G 1 Link to post Share on other sites More sharing options...
d_w_wolves Posted February 10, 2020 Share #19 Posted February 10, 2020 Am 7.2.2020 um 15:39 schrieb ramarren: "Yes, No, Maybe?" Never used one, never got a scratch or chipped an LCD cover either. I don't see the point, for me at least. G I agree Link to post Share on other sites More sharing options...
Einst_Stein Posted February 15, 2020 Share #20 Posted February 15, 2020 On 2/7/2020 at 6:39 AM, ramarren said: "Yes, No, Maybe?" Never used one, never got a scratch or chipped an LCD cover either. I don't see the point, for me at least. G This reminds me a comment: "I never fasten my seat belt, and I am still alive!" Link to post Share on other sites More sharing options...
