Memory card won't eject
Is it possible the card was put in the wrong way?
Leica seems to be the only manufacturer I've come across where you put the card in with the contacts facing up, so one needs to be mindful of this.
Normally the card will resist going in the wrong way, however.
I wish I'd seen this earlier so you wouldn't have to send the camera away. If you haven't got a suitable pair of flat nosed pliers ....
This is how you remove a stuck card: You need a piece of thin card cut so that it can be inserted into the gap between the card and the back of the camera. You will also need a few cms of single sided adhesive tape cut so that it's a little narrower than the width of a card. With the adhesive side of the tape facing the card carefully insert 1-2 cms of the tape into the gap between the SD card and the back of the camera. Holding the tape in place now insert the card into the gap between the back of the tape and the camera. This presses the adhesive tape onto the SD card. Remove the cardboard and carefully pull on the tape to remove the SD card. I've tried this - and it works without having to use the eject mechanism.
Of course if the eject mechanism is broken rather than the card being stuck then you will ultimately have to send the camera for repair.
Bob.
This is the third time I've tried to write this email. We've lost power for several minutes twice in the last half hour!
Thanks for your suggestions. I hit myself in the forehead after reading Pico's. By that time, though, the body was packed and ready to ship. It already had one very minor issue - the body occasionally not recognizing 6-bit coding - Carmen Vargas told me there is a fix for that - that I hadn't wanted to send it in for, since it rarely occurred.
Roxana at Allendale tells me that they can have the body back to me reasonably quickly, I'm traveling overseas in a few weeks, and I didn't want to chance this happening again then.
That said - pliers!
Bob.
I only just saw this thread - but this technique is exactly what i used to use back when i was fixing cameras, especially removing stuck batteries. you really don't need much area stuck down, as you are pulling it in "shear" not peeling it off.
I once had an SD card that wasn't ejecting normally. With a little brute force I managed to pull it out and noticed that one of the thin plastic ribs that separate the contacts on the card had become detached on one end and had presumably been sticking out and preventing the card from ejecting. Might be similar in this case?
The plastic casing can also split, causing a jam. Brute force works in that case. I would not hesitate to pull it out by force with this problem. If the slot is the culprit it will have to be replaced anyway.
