aesop Posted May 4, 2014 Share #1 Posted May 4, 2014 Advertisement (gone after registration) Help required for a rather odd situation. I need to develop an important 35mm roll of Ilford FP4+ erroneously rated at ISO 400 (yup, I know) in Kodak HC110. The Massive Dev Chart has no output for this specific rating and I have done a fair bit of research without any joy, so I would appreciate any real-world input (including successful real-world approximations) on time and dilution. Many thanks in advance. Link to post Share on other sites More sharing options...
Advertisement Posted May 4, 2014 Posted May 4, 2014 Hi aesop, Take a look here How long to develop FP4+(@ISO 400) in HC110? . I'm sure you'll find what you were looking for!
250swb Posted May 4, 2014 Share #2 Posted May 4, 2014 I wouldn't use HC110 for push processing. If you want to retain fine (ish) grain I'd use Ilford DD-X, MDC says 18mins at 20c. Steve Link to post Share on other sites More sharing options...
Stealth3kpl Posted May 4, 2014 Share #3 Posted May 4, 2014 Expose and develop another film to be certain. Diafine? Pete Link to post Share on other sites More sharing options...
Jeff S Posted May 5, 2014 Share #4 Posted May 5, 2014 Assuming you need to stick to that developer for that specific roll, why not (mis-)expose another roll, or 2 or 3, the same way and use some trial and error with HC-110 to determine the best workflow for your intended results. Jeff Link to post Share on other sites More sharing options...
aesop Posted May 5, 2014 Author Share #5 Posted May 5, 2014 ...thanks, Steve, Pete and Jeff. I went on to expose two other rolls of FP4+ at ISO 400 and determined (through a combination of your input, approximation, experience and common sense) that 10 minutes at 24˚ would work just fine with HC110 dilution A. I am please to report that it did. Incidentally, Steve, there is little discernible extra grain. Again, thanks for your prompt, no-nonsense and succinct input. Link to post Share on other sites More sharing options...
