ironringer Posted January 5, 2014 Share #1 Posted January 5, 2014 Advertisement (gone after registration) Could the experts please tell me how to remove an M-mount adapter from my 5 cm f3.5 Elmar screwmount lens, just received from an eBay purchase? This lens was being used on an M2. I don't want to damage anything and wish to use the Elmar on my IIIf camera. Maybe the M adapter just screws on and off? Are there any retaining screws or clips to remove? Happy New Year to fellow enthusiasts, from Montreal Link to post Share on other sites More sharing options...
Advertisement Posted January 5, 2014 Posted January 5, 2014 Hi ironringer, Take a look here how to remove M adapter from 5 cm screwmount Elmar?. I'm sure you'll find what you were looking for!
pop Posted January 5, 2014 Share #2 Posted January 5, 2014 It screws on and off, the same as on the IIIf.Since the adapter ring is a bit difficult to hold, press it onto a flat and slightly sticky surface. There are silicon pads which do exactly that. Mine is a "smart pad" (Smart Pad, Smartpad 2007). There are similar pads which are sold as jar opening aids. Link to post Share on other sites More sharing options...
TomB_tx Posted January 5, 2014 Share #3 Posted January 5, 2014 Normally you can use a Leica rear cap as a wrench to get a better grip on the adapter - perhaps a cheap generic cap in case it is really stuck and harms the cap. I've also heard of people using loctite to attach the adapter permanently, in which case... Link to post Share on other sites More sharing options...
UliWer Posted January 6, 2014 Share #4 Posted January 6, 2014 You run the risk of ruining you rear caps if you use them to remove an adapter (i have several spoiled by trying this.) The easiest and safest way is pressing the release button on your M and turn the lens against the clock -the lens will unscrew from the adapter, so you can remove it without applying force. Link to post Share on other sites More sharing options...
Guest Mr. B Posted January 6, 2014 Share #5 Posted January 6, 2014 One of those rubber pads that is used to open jars should work. At least it does for me. Mr. B Link to post Share on other sites More sharing options...
Keith (M) Posted January 6, 2014 Share #6 Posted January 6, 2014 When in London last, I bought a LTM adaptor from Red Dot for my 5cm Summicron. The shop very kindly provided an endcap that three small bosses on it, which engage with the three recesses in the adaptor (see attached photos). Have not needed to use this facility (yet!) but it could prove very useful. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/219638-how-to-remove-m-adapter-from-5-cm-screwmount-elmar/?do=findComment&comment=2502921'>More sharing options...
jaapv Posted January 6, 2014 Share #7 Posted January 6, 2014 Advertisement (gone after registration) Yes they are very useful and old lenscaps have them, but they are meant to remove the adapter from the M camera. To remove the lens from the adapter simply unscrew it when mounted on the M body, if it is very tight do so in the unlocked position not to damage the lens lock. Link to post Share on other sites More sharing options...
Keith (M) Posted January 6, 2014 Share #8 Posted January 6, 2014 Yes they are very useful and old lenscaps have them, but they are meant to remove the adapter from the M camera. To remove the lens from the adapter simply unscrew it when mounted on the M body, if it is very tight do so in the unlocked position not to damage the lens lock. Whoops - you are of course absolutely right! Brain fade on my part... Link to post Share on other sites More sharing options...
ironringer Posted January 10, 2014 Author Share #9 Posted January 10, 2014 Thank you "pop" from near Basel and others for good advice. Once I knew how it was supposed to work, I unscrewed the M adapter easily from my screwmount Elmar - it was not glued (!) or too tight. I'll post my next question in a new topic. Link to post Share on other sites More sharing options...
