Remote sync cable for flash
Jessestr
Hey all
I'm shooting with a Leica M8 and I always shoot natural light but I wan't to try a one light setup with shoot trough umbrella for some nice soft black and white shots.
I have a Canon Speedlite 580EX II that I want to use for flash. As I don't want to give money to wireless triggers.. are there cables out there for a leica that can trigger a flash?
Thanks!
I suggest the same setup I an currently using with my Cheetah CL-360 and my M9. I put a Nikon AS-15 in the M9's flash shoe
Nikon AS-15 Sync Terminal Adapter (Hot Shoe to PC) 3066 B&H
and connect to the flash using a PC cord. A Nikon or universal TTL cord would probably work as well, but they are more expensive and will not let you get your flash very far away.
The PC cable just conducts the signal from the large center conductor in the flash shoe. The signal that tells the flash to fire. The TTL cables conduct the signals from all the connections in the flash shoe. Those connections are usually unnecessary when using a non-Leica flash and in some cases can cause issues.
Thanks.
I've been figuring out that I can't find any PC cable for the 580EX II speedlite. As it's also a MALE connection. So I need a Male-Male.
As you can see this won't work. I don't know what to get......
Thanks.
Where did you find that hot-shoe/sync adapter pictured? The Nikon AS-15 works fine, but I'd like something I can slot an external viewfinder into when I shoot mondo wide-angle with off-camera flash.
