Stealth3kpl Posted October 23, 2013 Share #1 Posted October 23, 2013 Advertisement (gone after registration) I've purchased a tool to line up my images vertically. I've read somewhere that I should use a little acetate to melt the glue keeping the assembly stable. Do I just dip the tool in acetate then hope it comes off the tool in the right place?? Also, should I be trying to apply glue following adjustment? Perhaps melting the glue isn't necessary? Pete Link to post Share on other sites More sharing options...
Advertisement Posted October 23, 2013 Posted October 23, 2013 Hi Stealth3kpl, Take a look here M9 vertical rangefinder adjustment. I'm sure you'll find what you were looking for!
TonyField Posted October 23, 2013 Share #2 Posted October 23, 2013 I have not done this in years However, a very small drop will soften the locking glue. The adjustment should be done while the glue is loose. Unless you accidentally removed some of the glue, simply let it re-dry and it will be stable. Link to post Share on other sites More sharing options...
jdlaing Posted October 23, 2013 Share #3 Posted October 23, 2013 I've purchased a tool to line up my images vertically. I've read somewhere that I should use a little acetate to melt the glue keeping the assembly stable. Do I just dip the tool in acetate then hope it comes off the tool in the right place?? Also, should I be trying to apply glue following adjustment? Perhaps melting the glue isn't necessary?Pete AceTONE It is a paint that locks the adjustment. A Q-tip would work better but be careful not to dribble the acetone around. A small drop is all that's necessary. Link to post Share on other sites More sharing options...
Stealth3kpl Posted October 23, 2013 Author Share #4 Posted October 23, 2013 Ah yes, clerical error, I meant acetone. Acetate's a material. Thanks for the tip. I thought I'd just dip the tool in the acetone. Pete Link to post Share on other sites More sharing options...
jdlaing Posted October 23, 2013 Share #5 Posted October 23, 2013 Ah yes, clerical error, I meant acetone. Acetate's a material. Thanks for the tip. I thought I'd just dip the tool in the acetone.Pete I don't think it is quite enough but give it a try. Link to post Share on other sites More sharing options...
A Sfeir Posted January 10, 2014 Share #6 Posted January 10, 2014 I've purchased a tool to line up my images vertically. I've read somewhere that I should use a little acetate to melt the glue keeping the assembly stable. Do I just dip the tool in acetate then hope it comes off the tool in the right place?? Also, should I be trying to apply glue following adjustment? Perhaps melting the glue isn't necessary?Pete Care to tell me where did you purchase the tool from? Antoine Link to post Share on other sites More sharing options...
sblutter Posted January 21, 2014 Share #7 Posted January 21, 2014 Advertisement (gone after registration) I got mine from someone in China - Ebay? I forget. What I do recall is chickening out! Adjusting the angle of my glasses was easier - am pulling focus just fine. G'luck - or try DAG repair. He does a great job, also quick and reasonable Link to post Share on other sites More sharing options...
