M9 Shooting Blanks!
shashikiran
My M9 is two years old. I have been using it without any problems. For the last few months I've been using Sandisk Ultra 32 GB. No problems again.
Since this morning, when I take a picture in any mode, including Snapshot, I only get a blank screen. I changed lenses. Same situation. I downloaded once again the latest firmware and reloaded it. Problem remains.
Can anybody tell me what's wrong? I have not dropped the camera or anything. The settings are all the same. I live in India, so I would have to carry it abroad for repair.
Thanks for any help!
How many images are on the card? Can you put it in a card reader and copy files to it or create a new folder? Can you look at it and see whether it is full? If it appears full, and has fewer images than it should, then it is probably a counterfeit card.
Try backing-up the card and reformat it in-camera, or even better, use SD Formatter.
Thanks. I downloaded and reformatted with SD Formatter. No luck. Also, I've been using this card for months now with no problem at all.
I used to get this with my M9 a fair bit. When you open the files on your computer do they have a slight amount of multicoloured noise? Mine used to do that. No idea why. Was frustrating to miss some shots.
No. My screen is altogether blank. Sometimes completely white, sometimes completely black. Both on the camera's LCD, and the Mac.
I've had seen this kind of things very occasionally on my two M9 bodies - no more than a handful of occurrences - often when shooting fast in single mode. More of a random glitch than a permanent problem.
If a new card and a fresh firmware install do not solve the issue, I'm afraid your camera needs a holiday in Solms to get the electronics fixed.
I would find the latest firmware (1.196 I believe) and reload it. More with the M8 than the M9, I found that this could sort anomalous behaviour. It certainly would not do any harm to your M9.
Wilson
Wilson
The OP says he's done that already...
...Also, I've been using this card for months now with no problem at all.
That can happen. I would strongly advocate using a different brand of SD card. The M9 suffered some frustrating problems with some Sandisk memory cards. I switched to Lexar and, touch wood, have never had any problem with performance. Bit the bullet!
Right!
Right. I'm going to get me a new card tomorrow (Monday). I'm praying…
