Leica m2 won't lock my lens?!
Landberg
Sometimes the rebate in the lens flange that accepts the locking catch can swage over on the edges, the metal 'spreads' due to wear as it is dragged across the catch each time the lens is mounted. And sometimes you can even buy a new lens (CV or Zeiss) that still has some machining swarf around the inside edge of this rebate which does the same thing, it stops the catch on the body locating in the cutout to lock the lens. So perhaps have a look, and if it looks rough or swaged over use a sharp knife blade to run around the inside edge of the rebate in the lens mount.
Steve
It does lock on my M5? Could it still be the lens?
Yes, your M5 catch my simply have a slightly different tolerance, or even be worn itself making it smaller. This is only an idea, but its worth a close look before blaming springs and other mechanical things before sending it off to a techie un-necessarily.
Steve
