Leica M 240 battery
Pelpa78
  • Replies 61
  • Created
  • Last Reply
I don't think there are any. But why try and save 70$ when you have just bought a 7000 $ camera?:confused:
There are third-party batteries for the M8/9/MM, but over the years there has not been one that was completely free of issues. I doubt it will be different for the M, even if Chinese battery clones come to the market in the future.
Precisely because I spent already 7000$ (it was a huge expense for me) I do not want to keep on spending... I just bought a new backpack (100$) and a half case (130$) in order to protect it. Now the additional battery... It could be a neverending spending... :)
If the difference in just 70$, I know it would be better the official battery... I though it could had been far less cheap... like 20/30 dollars per battery...
It could - and probably will be some time in the future. But if the M9 batteries are anything to go ,by, the electronics will have to be retro-engineered, which means that the communication with the camera will be flakey - not indicating the state of charge, for instance.
The M appears to be sensitive to the behaviour of the battery too.
The good news is that after a couple of recharging cycles the battery seems to cope with 8gb
of images if you don't use liveview all the time ( I have no experience of shooting continually with liveview so others might advise). If you are using the camera to the point where this is insufficient capacity between charges, then the second battery would seem good value.
The bad news is some would advise a spare charger as well!
Don't let these little things spoil what is a great camera, and hope you enjoy as much as many here.
What I have read, DSTE should be a reliable supplier.
But they do not deliver to Germany, UK, Italy, .... so it seems to be clear that the main buyer is protecting his markets.
Holland is OK, maybe Jaap can organize some batteries ;-)
Uwe
Sent from my iPhone using Forum Runner
M9 generics were cheap otoh very expensive. After using the generic battery the camera electronics became less reliable and eventually had to be sent to Leica for replacement. In addition the charger now misbehaves, it works but the battery level indication will flash wildly until the battery is removed and placed again. I'll never buy another generic, a savings of a few dollars can cost much more in repairs and the inconvenience of malfunctioning camera/charger. Can the behavior of the M9 be generalized to the M?
The risk is too great for the small savings.
Never heard of a body needing repairs because of generic batteries so far. As far as my M8.2 is concerned, generic batteries need just to be fully discharged in the camera before recharging them to avoid false meter readings. Can't wait to test one on my M240.
So that's curious. All my plastic bags say "Made by Varta in Indonesia". But then when I look very closely at the battery itself it says "Leica Camera Korea Ltd."
So the plastic is made in Indonesia and the battery in Korea as you wisely point out.
So now Leica has a Korean factory or sourcing center in Korea it seems. Sounds reasonable.
