My first Leica film
Brenton C
First roll through my M3 (with Summicron 50/2), and the first film I've taken in, ohhhh, 18 years I'm sure.
Some troubles here, and I'd value your input. The film is Portra 160.
The first pic, a casual snap over a pint. It's grainy, but worse, it looks like the shutter got in the way of the exposure. From studying my notes, this happened on every picture taken at 1/1000. This was taken at F2, with skylight filter, using incident (Hah, Freudian typo, I typed "indicent") metering.
Second pic, I didn't get down what the exposure was. The picture looks dark (under exposed?) and grainy. It was a sunny day, with sun obscured by some clouds, but I was careful to take the meter reading (ambient / incidental, not reflected) just before the shot.
F stop might have been F2. I was a little F2 happy with this roll, experimenting a lot with Bokeh. I read that maybe F4 would have been sharper.
Third, again the shutter problem (I think) at 1/1000. You can see the black curtain at the top. F2, no filter, metering again with the incidental method -- this was almost a nice picture!
So, any suggestions, diagnoses, advices would be very welcome on several points:
1) I figure I have a broken camera, at least at 1/1000.
2) I'm surprised it's so grainy.
3) Also, are the colours a little under saturated?
4) Could I have damaged the film by carrying the camera in the car constantly, all the while I was taking this roll?
5) Any other points of note?
Thank you in advance.
The shutter is "capping" - meaning the trailing curtain is moving faster than the leading curtain and catching up at 1/1000. It will also cause uneven exposure at other speeds, but slow speeds may give good results. It really needs cleaning, lubricating, adjusting (CLA) by a good Leica tech.
James, Tom,
Thanks for your input.
Looks like I'll be sending it out for a tune up -- or back to Red Dot from where it came.
Might be quicker to just send it to competent tech on this side of the pond.
Is there a list on the site? I better have a look, but if there are recommendations, I'd welcome those.
While I'm on the topic of having the camera adjusted, I found it very hard to focus, many times. It was very difficult to see the "patch" to bring it in to alignment. I wonder if the range finder might need a look.
James, Tom,
I know it is a PITA but if Red Dot sold it with a warranty that's still in date I would let them sort it out and ask them not to send it back until it is. As for your focusing problems, well, it is tempting to find one fault and add another, but not seeing the patch is mostly due to having your finger over the illumination window.
Steve
I had a very nice chat with Horst Wenzel last night. He's the Leica go to tech in Vancouver, and highly praised on the photo boards.
He encouraged me to use the camera a bit more, but avoiding 1/1000th, and see how another roll or two turn out.
I've still got half a roll of Ektar 100 in the camera-- i'll try and use that over the week end here.
On the range finder, Horst said to focus the lens on infinite and check the patches line up.
From another forum someone posted pix of the view finder view, and from those images and that discussion, it looks like my rf is ok... I take it that it's not always super easy to see it well. A high contrast between subject and backgroud does make it easy to see.
I'd like to add that I'm pleased the first roll wasn't a total disappointment.
This picture turned out pretty nice, I thought.
Yes ist did, it sometimes helps to let each time work as often
as You are able to...
Mechanics dont like to stand still.
KR Matt
PS
Once, the long times on my near to new M stopped working
I tried this: Repeating one of the shorts again and again,suddenly it works well, now they do there Job, its not a bug its a Leica ;)
There's a small unexposed band on that image also. Finish the film you have & see how that looks, maybe exercise the shutter (no film in camera) and try another test roll, at all speeds.
If the problem remains then contact Red Dot. AFAIK they give some months warranty on used gear so I'm sure they'll sort it out for you.
Im pretty sure he means that unexposed bar on the right. The film was professionally scanned when developed, so it wasnt my clumsiness, if that nelps.
As soon as im home today i'll carefully look at the others. Im in revelstoke BC today ... I was hoping to get a nice picture or two. Beautiful town In The Rockies.
