I edited the copyright info in my camera, but if I open it in LR or exiftool, the top item (called Information in the camera menu) appears as the following between the quotes: "entered text ___________I". This is even more intriguing because the entered text, which is my email address, takes up all the available squares in the camera editor. The bottom item, where I entered my name looks correctly.
Has anybody else observed this?
The only reason I use it is because in case of loss of theft of the camera there is a place where my name and email address can be found (and on all the picture taken with the camera). Besides that I use LR settings on import, just like JaapV
I always add copyright info on import; the camera has too few positions anyway and it lacks the © symbol!:eek:
That's fine because the
© symbol
isn't necessary (or sufficient?) for a copyright notice. "Copyright" is though.
Rules might be different in Copyright fields, but here's an excerpt from some well-known instructions in copyrighting your work:
Always use the English word “Copyright”; by international convention, this is used worldwide, even for material in other languages. The copyright symbol “©” can be included if you wish (and your character set supports it), but it's not necessary. There is no legal significance to using the three-character sequence “©”, although it does no harm."
Yes, it's very buggy, set it at import time, just make sure it has at least the word "Copyright", your name, and the date, otherwise it might not be enforceable. You can add other stuff if you like.
© symbol
If I have to spell out "copyright" I cannot imagine what Leica was thinking of by using so few positions.:mad:
I always add my copyright info by ImageIngester.
In the Copyright status field, mine displays "unknown". The other options are copyrighted or public domain. In the actual copyright field, mine displays the ISO value or auto ISO :confused:
. I have no idea whether this is due to camera or program or both.
I never bothered to fiddle further with this in camera thus far but I can of course add data on import as desired.
  • 5 years later...
Instead of stating a new thread thought I revive this one. Was this issue ever addressed in firmware updates? Have 2.0.5.0 firmware currently in my 240's.
I tried over and over again to enter my information into these fields and it disappears every time. It would be nice to have stick. Any suggestion?
It's not a big deal really because I add the information during import using photo mechanic. It would be nice to have it happen in camera though.
Issues with copyright and artist information in exif data have been fixed in October 2013 since firmware update 2.0.0.11 in my book. No problem with the current firmware 2.0.5.0 as far as my M240 is concerned anyway.
Edited by lct
For now it seems to be holding it own using  a profile.
Have changed a few things in menu and have noticed that the user profile reverts back to default. If save the changes made in the menu to previous saved profile everything is good to go. Kinda of PIA, yet it works.
