pop Posted October 5, 2013 Share #21 Posted October 5, 2013 Advertisement (gone after registration) BUMP What Pete says is good advice. If only I'd seen it before. 1 Link to post Share on other sites More sharing options...
Advertisement Posted October 5, 2013 Posted October 5, 2013 Hi pop, Take a look here WARNING! M (Typ 240) and Bellows II . I'm sure you'll find what you were looking for!
farnz Posted October 5, 2013 Author Share #22 Posted October 5, 2013 Philipp, The warning is also in the FAQ thread but since the M240 FAQ thread has been amalgamated with the M8//M8.2/M9/M9-P/MM FAQ thread it's not as obvious. Now that the M240 has its own sub forum it would be great if the M240 FAQ thread could be split away again. I would assume it to be reasonably straightforward and costing little time because logically the M240 entries will naturally be dated later and therefore at the end of the thread. Pete. 1 Link to post Share on other sites More sharing options...
Knorp Posted October 6, 2013 Share #23 Posted October 6, 2013 This also reminds me why we still need a source for an adapter tube which eliminates the need for the visoflex housing. I think Wilson's given up on this project in despair - anyone with any thoughts or projects? I'd still be in the market for this. There is a Novoflex LEM/VIS adapter available now. Kind regards. Link to post Share on other sites More sharing options...
jaques Posted October 6, 2013 Share #24 Posted October 6, 2013 This also reminds me why we still need a source for an adapter tube which eliminates the need for the visoflex housing. I think Wilson's given up on this project in despair - anyone with any thoughts or projects? I'd still be in the market for this. is this what a TXBOO LTM tube already does? Anyone using the TXBOO on M240? 1 Link to post Share on other sites More sharing options...
0luke1 Posted July 21, 2018 Share #25 Posted July 21, 2018 This thread came up in a search when I couldn’t get my M10 off the bellows. Since I figured out a solution, I thought I’d put it here. There’s enough room for a thin piece of plastic in there which will depress the lens release button on the body enough. Once you get the body started, you don’t need to keep the lens release button depressed. My bellows has a rectangular tab on the left side which, when depressed will allow you to rotate the body, but does nothing to release it. Looking inside towards the camera body you’ll see that the assembly rotates with the body. Link to post Share on other sites More sharing options...
dau Posted July 22, 2018 Share #26 Posted July 22, 2018 This also reminds me why we still need a source for an adapter tube which eliminates the need for the visoflex housing. I think Wilson's given up on this project in despair - anyone with any thoughts or projects? I'd still be in the market for this. See post #6 above. Using both the M>R and R>M adapters will do. Link to post Share on other sites More sharing options...
kaspar Posted May 22, 2021 Share #27 Posted May 22, 2021 Advertisement (gone after registration) Dear Farnz, Thank you very much. I was also so unknowing to attach an old bellow to my new M 240. Once done, I could not release it. I was in panic. Then, after a while, I started thinking again. I consulted Google witn some likely words as bellows and Balgen. Not useful. Then I consulted this forum of which I am an old member, but was not on it for many years. Had to find and reset password, etc. Then I found your contribution. This calmed me very much. I started thinking even more again. By loosening some parts of the bellow by screwdriver I finally succeeded in shredding this Monster from my beloved camera and from myself. Thanks to you. I love adventures, but not of this ugly kind. I am not a professional photographer (but a psychiatrist). Yours, Kaspar 1 Link to post Share on other sites More sharing options...
