Customer Satisfaction with M240 Color Survey.
Rick
  • Replies 57
  • Created
  • Last Reply
wow, did you read the first post?
Putz.
The question was not directed at you.
I took over 2700 images with it.
I get it back in about a month and at that point I own it.
Mind thine own business.
Putz.
If, you currently own one then I see no reason you can't answer the question. I currently own one that is vacationing in Solms to get some glue squirted on its lugs. I should vote NO just out of spite. :rolleyes:
Yes 27
No 1
There is some explanation and examples why I tend to "No" given in my article. But I also think, it can no be simply reduced to Yes/No. The files contain all, what you need to be enabled to get a nice image at the end (but this is true for many other cameras as well). The question should be, if the default profiles in Adobe LR/ACR (or embedded in the DNG) already satisfy you. Here I would say in many situations: "No", because it takes me too much time and effort to make the necessary adjustments (and even then it does not always match others expectations what also may depend on my PP skills). If you want to comment on my findings, please do that here.
